Turbo pump help please
Re: Turbo pump help please
Postby gardener68 » Mon Apr 27, 2009 11:57 am
alanwh wrote:
up the boost a bit too :wink:
please explain how to go about this :idea: :?:
gardener68
Postby alanwh » Mon Apr 27, 2009 1:13 pm
Put in a Manual boost control, they're about £30. You'll need a good accurate boost guage as well though :!:
You can shorten the wastegate actuator rod a couple of mil, but it's not really recomended to move it from stock.
Don't do any adjustments without a boost guage fitted first :wink:
Only adjust by small increments and don't go mad I've heard of crazy boosts but wouldn't go much above 1 bar. Think the 100ps is about .8 standard
alanwh
Postby gardener68 » Mon Apr 27, 2009 1:52 pm
so in theory i up the boost then re-increase the max fueling screw to produce the same small amount of black smoke on heavy throttle just like i did when i first converted from epic to 146 bosch.
where is the best or easiest place to connect up a take off for the boost guage :?:
thanks russ
gardener68
Postby alanwh » Mon Apr 27, 2009 2:17 pm
gardener68 wrote:so in theory i up the boost then re-increase the max fueling screw to produce the same small amount of black smoke on heavy throttle just like i did when i first converted from epic to 146 bosch.
thanks russ
That's it mate, but you can't mad with the standard 146 as the further you turn it up the more you compress the injection duration.
Take off is best from the manifold. Have you got a brass threaded plug in the middle, where a flamestart glow plug could be fitted ?
alanwh
Postby gardener68 » Mon Apr 27, 2009 10:46 pm
there is a large ish brass blanking plug on the top of manifold near the back.
should be able to drill and fix in a take of for gauge .
gardener68
Postby Guy88 » Mon Apr 27, 2009 10:59 pm
alanwh wrote:Put in a Manual boost control, they're about £30. You'll need a good accurate boost guage as well though :!:
on my conversion 10mm put the boost up about 0.2 bar
I ran at 1 bar no probs, turned the max fuel up 2 turns and then backed off the mid range to stop smoking
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Mon Apr 27, 2009 11:03 pm
gardener68 wrote:there is a large ish brass blanking plug on the top of manifold near the back.
:idea: What's wrong with using your original MAP* port for the gauge, especially as it will no longer be using the MAP sensor :?:
(*manifold absolute pressure sensor)
Postby alanwh » Mon Apr 27, 2009 11:14 pm
I unscrewed it Andy when I was looking for a take off for the LDA on the pump and it seemed to be sucking, you know like a venturi effect as the boost rushed past the hole. The flameplug hole seemed to be pressurised. Thinking about it now it doesn't make sense, so worth checking it before you drill the brass plug :-)
alanwh
Postby AndyG » Mon Apr 27, 2009 11:50 pm
Well my boost gauge works on that line, but above the blue plastic restriction valve (I think that's there because it helps to stabilise the reading of the pressure) :D
Postby Jim H » Sun May 03, 2009 6:31 pm
After turning the fuel right up on this existing pump & the advancing of the timing i have found it is 10 percent better on fuel. Look foward to fitting the 146 pump next Saturday :)
Plodding along.
Jim H
Postby Jim H » Sat May 09, 2009 6:03 pm
wowput this 146 pump on this afternoon. advanced the timimg. Turned mid range screw in 2 turns & overall screw in 1 1/2 turns.
Now it's got some go in it. It starts & sounds better, pulls quite well now.
Had chance to locktight the loose dipstick tube in while the pump was off.
Look foward to putting 100ps (blue spot) injectors in, Has anyone got any new ones spare?
Thanks again for all the help, Jim :D :D :D :D :D
Plodding along.
Jim H
Postby alanwh » Sat May 09, 2009 11:10 pm
Bloody hell Jim, that looks a cracking pump :D
Where'd you get it :?:.... Looks mint 8) 8)
alanwh
Postby Jim H » Sun May 10, 2009 6:35 pm
T'is that one off E Bay that Andy G pointed out. I was a bit concerned when it came without any covers on also it took ages to get fuel through. Been out in the truck again this afternoon & it's far better. It delivers power a lot smoother & goes up hill a lot better. Just got to see what the mpg is now.
Plodding along.
Jim H
Postby Retrohowla » Thu May 28, 2009 7:17 pm
This is a great thread, just about everything i need to know here for my 100ps/bosch145 conversion
Nice one guys!
If you own a transit, learn to weld
Retrohowla
Postby redeemer » Thu May 28, 2009 10:34 pm
Nice thread , right what Im looking for!
How about the new mpg offered from this setup? :roll:
And alanwh what is the manual boost control that you mentioned? is it a bleed valve that you can instal inside to increase or decrease max boost?? :D
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
cron
