Fitting Power Steering to Non-Power Steering Model
Postby AndyG » Wed Apr 26, 2006 6:16 pm
spanners wrote:can anybody tell me if a 1993 transit power steering rack will fit my 1987 mk3 they look the same or simialer thanks :D
Isn't the track (wheel to wheel) wider on a mk4 and mk5 compared to a a mk3 :?:
Postby Luke » Wed Apr 26, 2006 6:26 pm
i'm pritty sure it is - havent accuratly measured it but the difference may be on the hubs - which are different :!: im sure as ive had them side by side mk3-mk4 :D
Postby spanners » Wed Apr 26, 2006 6:33 pm
:D by the hubs do u mean were the track rod end fits to the hub ?
spanners
Postby transitgeoff » Wed Apr 26, 2006 7:01 pm
ask Woody, i stuck a 1999 rack on his mk3,there the same :wink:
transitgeoff
Postby Luke » Wed Apr 26, 2006 7:07 pm
spanners wrote::D by the hubs do u mean were the track rod end fits to the hub ?
no by the hubs i mean what the stud goes through :D
Postby transitgeoff » Wed Apr 26, 2006 7:22 pm
the only difference when fitting a late mk5 rack to a mk3 is the track rod ends, the stub axle assembly has smaller holes and you will need to fit the early track rod ends onto the late rack, the threads are the same so they are a direct swap,no hassle.
transitgeoff
Postby transitgeoff » Wed Apr 26, 2006 7:26 pm
oh and the bit Mike said about cutting a slot in a bolt is spot on,ive converted bundles of smileys and thats always a problem,the holes rust up,what i normally do is cut three slots at angles around a bolt then plenty of lube and an airgun keep winding the bolt in and out until it runs smooth :D
transitgeoff
Postby woody » Wed Apr 26, 2006 7:49 pm
THAT'S NICE TO KNOW GEOFF :) AND WHAT A GREAT JOB YOU DONE ON IT . IT'S A PLEASURE TO DRIVE IT SINCE YOU DONE MY POWER STEERING 8) THANKS AGAIN
woody
Postby transitgeoff » Wed Apr 26, 2006 8:19 pm
Glad your happy Dave,any problems or queries dont be afraid to ask,always happy to help mate :D
transitgeoff
Postby spanners » Wed Apr 26, 2006 10:03 pm
:D :D ha great i thought they looked the same but didnt want to buy one until i knew thanks alot let u no how i get on just one more thing what pas pump do i use mines a petrol 2ltr pinto cheers :D
spanners
