Transit 2.4 York Engine
Advertise any transit parts you have here free to other members!!
Postby Turnip » Mon May 11, 2009 10:08 pm
I have removed a 2.4 York from my 3 ton Unimog - I need more power. The engine looks crusty but always starts in a couple of revs if you heat for 20 secs. The rocker cover has a sticker saying Ford Recon unit. I put a new cam belt and water pump on 500 miles ago.
The engine has a modified sump and the vac pump hole is blanked off.
I dont want any time wasters or dreamers - it is in a field near Dursley Gloucestershire and I can help to load most Saturdays - otherwise the scrap yard is 1/2 a mile away.
It is free - any takers?
Turnip
Re: Transit 2.4 York Engine
Postby DodgeRover » Tue May 12, 2009 9:49 pm
Hi it might be worth posting this on some of the landrover/ range rover forums as well if there are no takers a few end up in those..
DodgeRover
Postby Turnip » Thu May 21, 2009 10:24 pm
This lump is heading for the scrappy very soon - last chance?
Turnip
Return to Free to good home!!
