MK6 Transit In Silver MWB or SWB Flat Top Wanted
Need a Tranny! Post Here!
Postby Mutley » Tue Dec 30, 2008 9:14 pm
I am looking for a Transit in Silver. The spec is flat top with a SWB or MWB the thing is I will need to fit a tow bar so it needs to be a 100ps or higher.
The Caravan it will tow is 870kg so from the VIN plate, the Transit Train Weight less the Transit Vehicle Weight must = more than 870kg.
Mutley
Re: MK6 Transit In Silver MWB or SWB Flat Top Wanted
Postby BigNeil » Tue Dec 30, 2008 10:21 pm
viewtopic.php?f=7&t=34566
not a mk6 but good looking van
BigNeil
Postby Scotty86 » Tue Dec 30, 2008 11:48 pm
You won't get a mk6 flat top MWB you only get SWB flat top, but you can get a mk7 MWB flat top :wink:
BigNeil wrote:http://www.fordtransit.org/forum/viewtopic.php?f=7&t=34566
Sure that van is sold now Neil :wink:
2017 Transit Custom SWB RSV
Scotty86
GLX Posse
Postby Mutley » Thu Jan 01, 2009 12:43 pm
Thank you very much for info much appreciated, but will I ever get SWB that I can use for towing ?, I have spent 3Mths and no joy. I thought going to a MWB it would be heavier so it would be ok, I fear a Mk7 would cost to much my budget is only £5k max. I am also unable to go Medium Height as it would not go in my Garage.
Mutley
Postby Luke » Thu Jan 01, 2009 12:52 pm
Mutley wrote:Thank you very much for info much appreciated, but will I ever get SWB that I can use for towing ?, I have spent 3Mths and no joy. I thought going to a MWB it would be heavier so it would be ok, I fear a Mk7 would cost to much my budget is only £5k max. I am also unable to go Medium Height as it would not go in my Garage.
at 870kg i'd have thought any transit would pull that fine - an ex rac would be ok as it'd have the towing diff but they are only 90ps :D
Postby Guy88 » Thu Jan 01, 2009 2:15 pm
My rac has over 5tonne GTW, 90ps, and a 4.6 diff thats a 330 SWB low top
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby sc_BK » Thu Jan 01, 2009 2:44 pm
One thing to watch with a RWD is it may not fit into your garage
Any 260 or 280 will be able to tow that, I've towed caravans of simillar weight behind my SWB med roof FWD 280 75ps. If you want to make it slightly easier for yourself go for a higher power engine or a remap
sc_BK
Postby Mutley » Fri Jan 02, 2009 5:48 pm
Thanks for advise but I am getting very confused, I agree any Transit would be ok to Tow my Caravan but the
Department For Transport state " Example you have a car with a maximum weight of 2180 kg and a train weight of 3980 kg the maximum towing capacity will be 3980 kg minus 2180 kg which gives a towing capacity of 1800kg"
To me then a great transit I have seen SWB flat top 300 model, weight 2880kg and train weight of 3500kg, so 3500kg minus 2800kg = 700kg and I need 870kg again no good, or as I say am I missing something. I know this Transit would Tow my Caravan no problem but the Law would say something different if I got stopped.
I see many Transits at Steam Rally's which I display at and they are towing Caravans, are they all breaking the Law ? as I say what calculation have I missed so as to get away with it. ?
Mutley
Postby sc_BK » Fri Jan 02, 2009 6:52 pm
Assuming you have the licence you can carry whatever load or tow whatever trailer you want so long as you don't exceed the Gross Vehicle Weight or the Gross Train Weight (or the axle weights)
A 280 SWB has a GVW of 2640 and GTW of 3500 so even with a fully loaded van you can still tow 860kg (so long as you don't go over on the axles)
sc_BK
Postby sharpy » Wed Mar 11, 2009 6:06 pm
Hi,
Ive got a 2004 53 plate for sale with towbar, i pull a car trailer and rally car with it and you wouldnt know it was there. its an 85. Look on the my transit blog and you will see some pictures.
sharpy
Postby h7thl » Thu Mar 19, 2009 8:28 pm
hi there i have a 2001 260 ps100 swb flat roof transit taxed and motd if you want to know more pm me and i will send you some pics
h7thl
Postby djdarch » Fri May 22, 2009 6:37 pm
I got a swb 52 plate executive 125 tdci in med steel blue (very nearly silver) its done 97k and its got full history up till last year when i got it, i have serviced the van myself sisnce then.
All the bells and whistles lectric windows heated screen etc and a really gutsty 125psi engine . its in good nick body wise with a couple of little dings (very minor) here and there, cleans up really well its been used as my only vehicle so ive looked after it. Its never been a builders van!
Id sell for £3500.
djdarch
Postby madmark » Sat May 23, 2009 5:01 am
the 125ps is the one to have for towing! i dont even know my caravans on the back! :shock: :lol: :lol: :lol: :lol:
Postby transit daft » Mon May 25, 2009 7:34 pm
i have a mk7with 23thousand miles on the clock mettalic silver its the 11o van very power full
transit daft
Return to Transits Wanted
