mk 2 5 speed gearbox
Re: mk 2 5 speed gearbox
Postby Neil » Sat May 30, 2009 10:29 pm
i think thats right althogh if the 5 speed was introduced on the mk3 in 86 then could some of the last mk2 sold been 5 speed :?:
Neil v6
Neil
Postby travlinman » Sat May 30, 2009 10:32 pm
Muttley wrote:Fords did not manufacture a 5 speed commercial box before the MT75. That box was never fitted by fords to the MK2..... FACT :!:
oh no not another transit mk2 with 5 speed box ebay https://www.ebay.co.uk/itm/320377617385&seller=&toolid=10018&30146553" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/320377617385 FACT :lol: :lol: :lol: :lol:
travlinman
Forum fool
Postby Muttley » Sat May 30, 2009 10:53 pm
Just because it has a 5 speed in it does not mean it was made that way. I was a ford Commercial technician from 1979 to 1986 and can tell you for sure that there were NO mk2 transits manufactured with a 5 speed box FACT. You dont seem to have read the original post properly, he was asking if there was a 5 speed made for the mk2. there was not. BUT you can retro-fit a type 9 or MT75. Does that spell it out for you or do you need to have extra lessons in understanding the english language :wink: The ebay no you quote is for a 2.0 PETROL engine RETRO-FITTED with a type 9 box OK
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby Neil » Sat May 30, 2009 11:40 pm
:lol: :lol: :lol: :lol: :lol: :lol: should twig that :!: so can you answer my puzzle :?: my mk 2 has a differant autobox than the c3 , and its factory fitted any ideas why :?:
Neil v6
Neil
Postby redeemer » Sun May 31, 2009 8:23 am
redeemer wrote:So for not having such confusion , should we have a sicky type topic in the info section, with pics , which gearbox is which and to what they where fitted originaly??
Or is there one and I haven't seen it? :lol:
Should we do this ??
well put mr Muttley 8) :lol: :lol:
Neil but yours If Im not mistaken was Special Veichle Order (SVO)? so could it be fitted like the ambys with the V6 and difereent box?
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby vana mana » Sun May 31, 2009 8:35 am
And i was just starting to enjoy this thread :lol: :lol: :lol: :lol: :lol:
vana mana
Postby Luke » Sun May 31, 2009 9:50 am
redeemer wrote: should we have a sicky type topic in the info section,
i dont think there is any need there's only 1 member in 13 thousand who thinks mk2's had a factory 5 speed :lol: :lol: :lol:
but what about a thread for identifying which box is which and pictures - so people know what box they have that would be a good idea :idea: :idea: :D
Postby Neil » Sun May 31, 2009 9:55 am
was the ambys automatic :?:
Neil v6
Neil
Postby madmark » Sun May 31, 2009 10:04 am
mk2 was overdrive only option and auto ,no type 9 5 speed! :wink: ask fred she has had hundreds of mk2,s! :wink:
Postby redeemer » Sun May 31, 2009 1:14 pm
Yes like that I meant!
Like the different engines thread with pics and specifiacations :idea: :idea:
redeemer
Postby manandvan » Sun May 31, 2009 2:30 pm
type 9 box first appeared in the mk3 generation as a van gearbox with a side mounted van gearstick and different gear clusters from the car variant, if you want to put it in a mk2 as a replacement to a 4 speed type g then its an easy swapover, box, x member, stick, speedo cable, and uses the same prop. :)
manandvan
Postby manandvan » Sun May 31, 2009 2:39 pm
and hers another one for you, overdrive boxes fitted to ambulances had stronger planetry gears in the overdrive unit made specifically for the extra thrash of the v6 essex engines!! :)
manandvan
Postby Luke » Sun May 31, 2009 4:10 pm
redeemer wrote:Yes like that I meant!
go on then post away :lol: :arrow:
viewtopic.php?f=14&t=46599
Postby Luke » Sun May 31, 2009 4:11 pm
manandvan wrote:type 9 box first appeared in the mk3 generation as a van gearbox with a side mounted van gearstick and different gear clusters from the car variant, if you want to put it in a mk2 as a replacement to a 4 speed type g then its an easy swapover, box, x member, stick, speedo cable, and uses the same prop. :)
dont you need to shorten the prop :?: i seem to remember having to chop 1½" ish off mine i thought the T9 was slightly longer :D
Postby Muttley » Sun May 31, 2009 5:53 pm
Its possible for an Ambulance to be fitted with the Ford C4 box, or even a Borg Warner when ford boxes were in short supply. Not all ambulances were auto. Does your box have the data plate still on it?
Muttley
Return to Mk 1 & 2
