Muttley wrote:Fords did not manufacture a 5 speed commercial box before the MT75. That box was never fitted by fords to the MK2..... FACT
travlinman wrote:Muttley wrote:Fords did not manufacture a 5 speed commercial box before the MT75. That box was never fitted by fords to the MK2..... FACT
oh no not another transit mk2 with 5 speed box ebay https://www.ebay.co.uk/itm/320377617385&seller=&toolid=10018&45173121" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/320377617385 FACT![]()
redeemer wrote:So for not having such confusion , should we have a sicky type topic in the info section, with pics , which gearbox is which and to what they where fitted originaly??
Or is there one and I haven't seen it?
i dont think there is any need there's only 1 member in 13 thousand who thinks mk2's had a factory 5 speedredeemer wrote: should we have a sicky type topic in the info section,
was the ambys automaticredeemer wrote:redeemer wrote:So for not having such confusion , should we have a sicky type topic in the info section, with pics , which gearbox is which and to what they where fitted originaly??
Should we do this ??
well put mr Muttley![]()
Neil but yours If Im not mistaken was Special Veichle Order (SVO)? so could it be fitted like the ambys with the V6 and difereent box?
Luke wrote:i dont think there is any need there's only 1 member in 13 thousand who thinks mk2's had a factory 5 speedredeemer wrote: should we have a sicky type topic in the info section,![]()
but what about a thread for identifying which box is which and pictures - so people know what box they have that would be a good idea![]()
redeemer wrote:Yes like that I meant!
Like the different engines thread with pics and specifiacations![]()
manandvan wrote:type 9 box first appeared in the mk3 generation as a van gearbox with a side mounted van gearstick and different gear clusters from the car variant, if you want to put it in a mk2 as a replacement to a 4 speed type g then its an easy swapover, box, x member, stick, speedo cable, and uses the same prop.
Neil wrote:was the ambys automaticredeemer wrote:redeemer wrote:So for not having such confusion , should we have a sicky type topic in the info section, with pics , which gearbox is which and to what they where fitted originaly??
