Master Cylinder & Servo for MK2 transit
Postby chrisandmark » Sun Apr 30, 2006 9:09 pm
Any ideas where I can get them from for a MK 2 transit, 2.5di diesel engine?
Made 50-odd phone calls to scrap yards and dealers over the weekend and have turned up a blank so far.
It's getting kinda desparate now as until this work is done I'm off the road and not working. I'm in Birmingham but definitely don't mind travelling for the parts, I didn't know they were going to be so hard to find.
Thanks in advance.
Mark
:D
chrisandmark
Postby Luke » Sun Apr 30, 2006 9:11 pm
what about converting to a mk3 :? havent done it myself but if i was in your position i'd be seriously considering it!! :D
dont know if fred has :?
aslo why do you need both :?:
:D
Postby Luke » Sun Apr 30, 2006 9:13 pm
and try the parts wanted on here!!! :D
Postby chrisandmark » Sun Apr 30, 2006 9:19 pm
Luke wrote:aslo why do you need both :?:
:D
Need both cos they've both gone at the same time...
Just posted on the 'wanted' and am about to look through the sale threads.
Cheers.
chrisandmark
Postby Gunslinger » Sun Apr 30, 2006 11:54 pm
i posted some in the ebay section a little while ago, and i also remember emailing the seller asking about one for my mk2 and he said he either had it or could get it (cant remember which now) but it was a little more than i could afford :(
sparesman i take it your a trader of some description .... you have an ebay shop too ?
Gunslinger
Postby rover » Mon May 01, 2006 12:19 am
The MK2 Master cylinder is definately still available as Fred got one a few weeks ago, there are two different types... One has a larger bore outlet on two of the pipes but you can get converters to reduce them to standard.
Rover.
rover
Postby FredTransit » Mon May 01, 2006 6:29 pm
rover wrote:The MK2 Master cylinder is definately still available as Fred got one a few weeks ago, there are two different types... One has a larger bore outlet on two of the pipes but you can get converters to reduce them to standard.
Rover.
Yup, the brake master is still available, the one with the odd two brake unions are cheaper (almost half the price), and the unions themselves are next to nothing but changing the pipes/unions takes a bit longer and the more expensive type is a straight fit. It depends how much time and money you have. The Mk2 brake master won't fit the Mk3 servo, so if you go this route you have to change both. Personally I wouldn't go for 2nd hand brake parts if they don't come from a van you have run yourself, of from somebody yoiu know.
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
