i was going to fill it with deisel and stick it on
tourneo2002 wrote:Just to add to the guys that fill the filter, it is not a quick job, fill it, let the level go down then gradually keep topping up the filter until it will not take anymore, allow around 5 minutes for this. Then simply fit the filter, start up and away. If it is not quite full, then it may start, but because of low fuel pressure you may get white smoke out the exhaust for a few minutes. DO NOT DRIVE IT UNTIL YOU HAVE FULL PRESSURE !!!
vansit1 wrote:what about the right front fuel line itself?
vansit1 wrote:do i also need to fill in the main fuel line that comes in from the front right or does the hp pump create its own suction via the filled up filter then?
someone also suggested to plug up the rear left line on the filter side with a wiener, but what line is that and what would this help to fix?
