MK7 RECOVERY BUILD
Re: MK7 RECOVERY BUILD
Postby Luke » Thu Jun 18, 2009 6:19 pm
looking well 8) 8)
Postby ARTCARCOM » Fri Jun 19, 2009 6:22 pm
marked c channel up today
and cut them all out and laid crossmembers in place ready to weld
i welded the 2nd crossmember from the cab as the 1st one is comming back out
to bend side rail in to meet the cab so that is why ive missed one out
because the 1st one can go in to the 4th crossmember and cut shorter one for behind cab (i think) :?
also welded the last one before beavertail and very last one
so heres some pictures of the ones ive welded
so tomorrow i can weld all others up and maybe bend front over and weld up
ARTCARCOM
Postby redeemer » Fri Jun 19, 2009 11:01 pm
it started taking shape already 8) 8)
Good work mate 8)
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby Paul 1 » Sat Jun 20, 2009 1:17 pm
I wish I could weld like that, its really taking shape :)
54 plate 260 MK6 SWB Exec pack 85 ps soon to be reemapped. Dead locks and arma plates on rear.
Paul 1
Postby ARTCARCOM » Sat Jun 20, 2009 7:12 pm
today marked every 4 inches at front on the side rails
then cut top bottom and inside leaving out side intact
then bent round to shape nicely to the back of cab
it was a bit springy so wrapped a small wratchet strap round
and wratcheted up till i got it right then tacked the back up
doesnt look like ive done much but ive welded all the top crossmembers in
and cut 1x1 box and run it were i think wheels would run to stop sheets sagging
when running car up
now just needs top grinding off so sheets lay nice and flat maybe do that tomorrow (fathers day) :(
ARTCARCOM
Postby ARTCARCOM » Sat Jun 20, 2009 7:19 pm
Paul 1 wrote:I wish I could weld like that, its really taking shape :)
thanks for that comment but im not the best welder in the world :o
but i did buy a new snapon welder and very very happy with it :D
best money ive spent in ages :wink:
ARTCARCOM
Postby Luke » Sat Jun 20, 2009 10:18 pm
ARTCARCOM wrote:Image
nice idea :idea: it's little touches like that that make all the difference 8) 8)
Postby Hitch » Sun Jun 21, 2009 6:16 pm
coming along nicely
wish i had time to do something like this and skills :)
if only could build one from wood haha
Hitch
Postby ARTCARCOM » Sun Jun 21, 2009 10:18 pm
bought some mudguards last week
thought id try and fit them before i make slides for my ramps
and still awaiting my new rear lights to come too
had an idea lets see what we can make with these bits of scraps of metal :idea: :?:
some mudguard brackets :D
welded a nut inside of box so it can swivel a bit cannot see really what i mean
i will dress them up when i take it off when ive done the slides for the ramps
so really its took me all day to make brackets for one side mudguards
tomorrow should be quicker i think :lol:
had a little problem with my mig it doesnt like the big bottles of gas so quess what
yes just a few off cuts and bolted to brackets were chains go through so can be removed easy :D
quick spray with etch primer just to take rusty look off it
ARTCARCOM
Postby ARTCARCOM » Mon Jun 22, 2009 11:02 pm
today dint get much done
took my sheets to fabricaters to get guilotined to length
and drew a sketch of how i want my headboard pressing out
went to get some 12mm round bar
cut them into 5 inch lengths and ground ends smooth
then but each one in vice
but a piece of pipe over the top
and i but a slight bend on each one
these are to be welded on the inside of my side rails for rope hooks
as well as the lashing rings on the top when finnished
just for the times you need to strap things done
because theres never no where to tie things down when needed
ARTCARCOM
Postby ARTCARCOM » Tue Jun 23, 2009 8:14 pm
well ive emailed my very detailed diagram
of my design for my side lockers :lol:
also ordered a new set of lights for the rear ive always used ford ones but lenses are
cracked so thought id splash out on new ones
havent done much today made another bracket for mudguard one left to do
awaiting lights then i can design my lighting board then do slides for ramps
pick my new 12,000lb britpart winch up never had much todo with them
but well see them cheap ones are ok on ebay but im on my second one on
my mk6 it didnt like pulling a 4dr hilux with diff jammed it started smoking
and refussed to play :x
ARTCARCOM
Postby bigmastif » Tue Jun 23, 2009 8:24 pm
great work again bud coming on awsome 8)
bigmastif
Postby ARTCARCOM » Wed Jun 24, 2009 6:18 pm
i went and picked my new winch up today :D
i thought it was xmas :lol:
ive always used the cheaper winches which have been ok
but im on with my second one on my mk6
so thought id give a little extra and see what they last like
dont get me wrong ive never heard of them before but
my last one didnt even have any name on at all lol
got other mudguard finnished
just really waiting for parts now to get on plus going on weekend break so i can chill
and think wish i was home doing my truck as you do :lol: :lol: :lol:
ARTCARCOM
Postby Luke » Wed Jun 24, 2009 6:27 pm
Britpart :shock: would that be made in Britain :?:
Postby Hitch » Wed Jun 24, 2009 8:43 pm
looks like another good days work
keep it up cant ait to see finished truck
Hitch
