ford transit c3 auto box testing
Postby spanners » Tue May 02, 2006 10:29 pm
:cry: alrite lads hopin u can help me some body told me on this how to check my autobox but i cant find the post anyway there goes he told me to but the van in drive foot on the brake and rev it up i did this the revs dont go above 1000rpm :?: but i cant remeber if he told me this was good or bad can anybody just conferm how totest again for me the proplem i have it doesnt seem to acc until it changes to second :?: it goes well apart from this i just want to no if there is a proplem cus im knackerd with out me van :evil: thanks hope u can help :idea: :idea: :idea:
spanners
Postby spanners » Tue May 02, 2006 10:33 pm
:oops: forgot to say i was offered a worg warner t35 box with torque convertor i no the box is different but does anybody no if the convertor is the same is was fitted to an essex engine(ford)capri :?:
spanners
Postby motorwise » Tue May 02, 2006 10:39 pm
don't know about the torque converter - but I have got somewhere a genuine dealer overhaul manual (I think it's for the C3)- if you want it drop me a line :D
http://www.motorwise.net
motorwise
C3 AUTOBOX
Postby BigMac » Tue May 02, 2006 10:51 pm
LOOK AT THE ACELERATER PUMP ON THE SIDE OF THE BOX ITS ON THE DRIVERS SIDE . SOME TIMES IT GETS CLOGED UP SO TAKE THE PIPE OFF AND LOOK TO SEE AND SMEL FOR PETROL . THE PIPE COMES DOWN FROM THE THE MANIFOLD VACUM . IT DOSE SOMETIMES GETBLOCKED.IF THAT IS OK THEN TAKE THE 10MM BOLT OUT OF THE PUMP AND TAKE THE PUMP OFF THE BOX.YOU WILL SEE A LONG PIN WHICH SHOULD MOVE IN AND OUT IF THIS DOSENT THEN CLEAN IT AND RE PLACE
BigMac
Re: ford transit c3 auto box testing
Postby AndyG » Tue May 02, 2006 11:23 pm
spanners wrote::cry: alrite lads hopin u can help me some body told me on this how to check my autobox but i cant find the post anyway there goes he told me to but the van in drive foot on the brake and rev it up i did this the revs dont go above 1000rpm :?: but i cant remeber if he told me this was good or bad can anybody just conferm how totest again for me the proplem i have it doesnt seem to acc until it changes to second :?: it goes well apart from this i just want to no if there is a proplem cus im knackerd with out me van :evil: thanks hope u can help :idea: :idea: :idea:
Hi spanners, It was me :D just got in from work :( The test was for the torque converter, to see if this was your trouble having a poor "start from rest"
I take it you did the test (I thought you took it down the road to the auto specialist) and yes you're right :D if the revs don't go over 1000rpm, your torque converter needs replacing NOT the transmission :!:
Postby spanners » Wed May 03, 2006 7:12 am
hi big mac i will try that thanks :idea: :(
spanners
Postby spanners » Wed May 03, 2006 7:18 am
hi andy g yes i was going to take in to auto gearbox place but he wanted £50 to check to over i would rather have the £50 to spent to fix it :!: :D yes i did the test that you told me didnt go over 1000rpm so is it the convertor then :?: just one thing if the box +convertor were ok what should it do :?: when i do this test :?: im going to start to look for one now u see do u no if an essex v6 to b/w t35 box is the same :?: thanks
spanners
Postby rover » Wed May 03, 2006 8:02 am
What it should do is rev right up through the range, if it only sits at 1000rpm then its is the tourque converter.
Cant help on the B/W box though
Rover.
rover
Postby spanners » Wed May 03, 2006 8:05 am
:cry: yes it only revs to 1000rpm then im in drive with the brakes on and reving it thanks lads :oops: :cry: :evil:
spanners
Postby tractive-effort » Thu May 04, 2006 10:17 am
Having owned a few MK2 Granada's with the C3 box I can tell you the T35 is a much better option. It has an uprated torque converter for a start! The C3 is ok, but can generally start giving you problems around the 100,000 miles mark if it's had a hard life up to there.
I believe the T35 will bolt straight on to a 2.8 Cologne engine/Essex V6 but as for pinto's DOHC's or whatever I'm afraid I don't know? Must be an adaptor plate available I would think :?:
tractive-effort
Postby spanners » Thu May 04, 2006 5:27 pm
so would you thiink that the t35 torque convert would fit to the pinto flywheel and if so would the bbe ok to use thanks :D
spanners
Postby MrMPuk » Thu May 04, 2006 6:07 pm
tractive-effort wrote:I believe the T35 will bolt straight on to a 2.8 Cologne engine/Essex V6 but as for pinto's DOHC's or whatever I'm afraid I don't know? Must be an adaptor plate available I would think :?:
The Cologne and the Essex have different stud patterns so maybe it wont fit both.
Postby spanners » Thu May 04, 2006 7:05 pm
the box ive got has got an essex bell housing will the pinto one fit on to the box ? :?:
spanners
Postby Luke » Thu May 04, 2006 7:08 pm
spanners wrote:the box ive got has got an essex bell housing will the pinto one fit on to the box ? :?:
not without a different bellhousing essex cologne and pinto are all different stud patterns!!! :)
Postby spanners » Thu May 04, 2006 10:23 pm
ok back to the drawing board with that :lol: :cry:
spanners
