100ps_drw_hicube wrote:all sorted nowwell nearly!
van drives ok but have got to get the new epic pump put on as the old one is chucking smoke out
Andyg wrote:100ps_drw_hicube wrote:all sorted nowwell nearly!
Can you not try advancing the timing a bit
100ps_drw_hicube wrote:Andyg wrote:100ps_drw_hicube wrote:all sorted nowwell nearly!
go on then explain please![]()
im lost on this one
MrMPuk wrote:That's not how you adjust the timing that's how you tighten the belt, if you move the pulley back you will have a slack belt!
MrMPuk wrote:If the pin is in you shouldn't be able to move the pump only the pulley. There is no adjsutment on this at all other than to tension the belt!
