Rear disc conversion!!!
Postby OxtonyxO » Sun Apr 30, 2006 8:29 am
looking good luke :D
OxtonyxO
Postby Luke » Sun May 07, 2006 8:30 pm
pritty boring pic but i needed to take it for the tech how to im writing!!!
they are the mounting bosses for the halfshafts - to make sure the disk is perfectly centred!!
hopefully fitting em this week!!! 8)
p.s. thanks for making em me dad!!! :D
Postby Luke » Mon May 08, 2006 6:17 pm
and this is what they look like welded to the halfshaft 8)
the axle is now gonna be fitted to the van and assembled in situ!!! :D
Postby Gunslinger » Mon May 08, 2006 6:57 pm
thats starting to look very interesting ..... now where did i put that mk3 rear axle and those old mk2 front disks :lol:
Gunslinger
Postby Luke » Wed May 10, 2006 8:29 pm
Hit a bit of a problem today :x found the brake disk centre is actually 0.5mm bigger than the wheel centre - doh!!! :(
I had assumed they were the same :oops: so my wheels wont fit on, anyway me dad is taking the halfshafts today and hopefully he will be able to get it all in the lathe and take a skim of the end :D
i can only assume merc hubs are stepped so the disk comes off easier - would be interesting to look at a merc hub to compair it :D
apart from that the axle is sitting on the van - just gotta fit all the calipers and pipe it up!!
then the next problem............................ the handbrake cable!!! :lol:
Postby Gunslinger » Thu May 11, 2006 12:51 am
i'm having trouble picturing the problem here, maybe becasue i'm not used to working on short wheel based axles
Gunslinger
Postby Luke » Thu May 11, 2006 12:08 pm
Gunslinger wrote:i'm having trouble picturing the problem here, maybe becasue i'm not used to working on short wheel based axles
basically looking at the halfshaft with the boss welded to it the brake disk goes over that no probs but the wheel wont go over :shock: yet :lol:
Postby rover » Thu May 11, 2006 12:33 pm
You would have the same problem trying to fit MK4 wheels to the front of a MK3 van.
Looking good though luke 8)
Cant wait to see it all fitted up, I'm tempted to have a drive up the M1 and sneek a peek :lol:
Rover.
rover
Postby Gunslinger » Fri May 12, 2006 4:29 pm
oh i see, so its the length of the bit you welded on .... i was thinking width :?
Gunslinger
Postby Luke » Fri May 12, 2006 5:22 pm
Gunslinger wrote:oh i see, so its the length of the bit you welded on .... i was thinking width :?
well :? we call it the diameter :wink: :lol:
Postby Gunslinger » Fri May 12, 2006 10:55 pm
:roll: picky picky :P
Gunslinger
Postby Luke » Sun May 14, 2006 6:52 pm
Well, me dad did the machining on friday :D went up today and they fitted spot on 8) i now have the disks, calipers and wheels all fitted on the back of the van!!!
The problem i mentioned earlier in the thread of the calipers catching on the springs wasnt a problem :D didnt know what i was thinking they are miles off :roll: :lol:
The arch clearance is perfect, might have only just got away with a mk3 axle but thte edge of the tyre would have been outside the body line!!! :?
ive had a quick look at the sierra handbrake cable and it looks slightly tricky - the main problem is the transit cable has unequal lengths whereas the sierra one is equal :(
anyone know if the granada one is the same as the sierra or not :?:
so just the handbrake, pipe it up - also need a new flexi hose and a diff input seal and jobs done :shock: :lol:
Postby Gunslinger » Sun May 14, 2006 8:15 pm
:) cant wait for you to tackle a twin wheel axle next !!!!
Gunslinger
Postby Luke » Sun May 28, 2006 9:29 pm
got the calipers piped up today! :D having a look at the handbrake cable - it looks like the sierra one will fit apparantly the granada one is longer if its the outer sheath part thats longer then it would be better to use that but my guess is its the cable length - if it is then the sierra one is the one to use!
the main problem is the tranny h/brake is off centre! it would be easyer to make the cable pull unequealy but im not 100% sure it would be any good for balance, i think it would but as it pulls equaly on the sierra to be safe im gonna try to get it the same!
im gonna cut the mounting brakets off the sierra next and weld them to the chassis crossmember where the tranny cable is mounted! then modify the linkage by shorteneing the rod so all the adjustment will be as it is on transit! the only thing is the pull wont be at right angles - so it will be slightly less efficient but the extra longer handbrake should make up for that :lol:
Postby Sundowner » Mon May 29, 2006 7:13 am
Looks great Luke
Cant wait for the techy
Yeah i know its big green and rusty so move your Porsche before i bash it with 460 cubes of fords finest cast iron
Sundowner
