1968 LWB Twinwheeler 2,6 V6 project
Re: 1968 LWB Twinwheeler 2,6 V6 project
Postby cartooner » Wed Jul 29, 2009 12:50 pm
I stand corrected. Thank you. Anyway, nice van!
cartooner
Postby spitfire » Wed Jul 29, 2009 4:20 pm
Todays work
The welds grinded down :)
Ketil
Ketil
Norway
ketil.frengen@norgespost.no
2,9 Cosworth V6 1968 mod LWB Twin wheeler
viewtopic.php?f=27&t=49610
spitfire
Postby spitfire » Thu Jul 30, 2009 10:39 pm
Bought this on Ebay today :) NOS from 03-1963 :D
Ketil
Ketil
Norway
spitfire
Postby spitfire » Mon Aug 03, 2009 4:19 pm
Today it has been in and out with the engine/gearbox day :) Testfitting and moved the engine 4 cm back, this was only because I am fitting a very big/thick cooler.
Had to massage the firewall because of the distributor was a thight fit.
And the 5 speed gearbox had to get some room also so a bit of cutting in the box section over it and had to take up a new hole for the gearstick about 48 cm rearwards :)
Ketil
Norway
spitfire
Postby irishtransit » Mon Aug 03, 2009 5:30 pm
coming on well.nice purchase from ebay
irishtransit
Postby spitfire » Tue Aug 04, 2009 5:22 pm
Today I have made up plates with nuts for the gearbox crossmember mounting, going to use the mk2 gearbox crossmember :)
Tackwelded the rear ones and drilled in the framerails for the front ones.
I will take pics when it is done :)
Ketil
Ketil
Norway
spitfire
Postby spitfire » Wed Aug 05, 2009 5:00 pm
The gearboxcrossmember in three parts :)
Tacked together
Her it is welded together
There it was done, thats was todays work :)
Ketil
Ketil
Norway
spitfire
Postby Luke » Wed Aug 05, 2009 6:13 pm
top stuff Ketil 8) 8)
Postby spitfire » Wed Aug 05, 2009 11:13 pm
Luke wrote:top stuff Ketil 8) 8)
:D Thanks :D
Ketil
Ketil
Norway
spitfire
Postby spitfire » Wed Aug 12, 2009 7:46 pm
Started with the cooler today, it is a bit over 2" thick and the out/in is going to be fixed after everything is fixed :D
That was todays work
Ketil
Ketil
Norway
spitfire
Postby spitfire » Thu Aug 13, 2009 4:29 pm
Without the front frame part
welded in, but not the side top plates yet
Paintet inside the frame
Plenty of space for the engine :)
Ketil
Norway
spitfire
Postby spitfire » Mon Aug 17, 2009 4:34 pm
Painted the inside of the frame before i started with the powersteering :D
Came this far today.
Ketil
Ketil
Norway
spitfire
Postby SCANIAMAN » Mon Aug 17, 2009 6:23 pm
very impressive :wink: ..convertion is coming along nicely ketil :D
'OWNER OF VINTAGE HAMMERITE PAINT ! .........not that weak new rubbish '
' JUST ME AND MY DOG TOMMY VAN DAMAGE'
SUPPLYING PROTECTION DOGS FOR OVER 2 DECADES
SCANIAMAN
Postby spitfire » Mon Aug 24, 2009 4:59 pm
Rear wheelwell
Not to bad to be 41 years old
Ketil
Ketil
Norway
spitfire
Postby Luke » Mon Aug 24, 2009 5:05 pm
not bad at all 8) - just a couple of repairs good as new :mrgreen:
