What is my radiator capacity V4 Essex
Postby welshrussell » Tue Aug 04, 2009 5:25 pm
I had to replace the water hose that goes from the pump to the thermostat housing, so whilst doing that, I drained the system from a tap at the bottom of my rad.
Flushed a fair few litres of clean water through her and started to refill her.
I looked in my Haynes Manual and it lists a V4 engine rad as having an 8.1 litre capacity.
Mine was full up after 6.5 litres - does this mean:
A blockage is causing the system to be full after 6.0 litres :?:
Is it a non standard rad :?:
Was water left in the system after draining from rad :?:
Had a problem with my camera cable, so can't upload any yet :( will go to Maplins tomorrow :D
Do good things - and good things will happen to you!
welshrussell
Re: What is my radiator capacity V4 Essex
Postby madmark » Tue Aug 04, 2009 5:28 pm
russ you would of still had the rest of the water in the engine block! :wink:
Postby welshrussell » Tue Aug 04, 2009 5:41 pm
madmark wrote:russ you would of still had the rest of the water in the engine block! :wink:
oh yes, thought so :oops:
Hence why I could only get 6.5 litres in :roll:
welshrussell
Return to Mk 1 & 2
