Vee4 wrote:Is it a Mk6? The ABS computer can be 'diagnosed' by a suitably equipped Ford dealer. If it's under warranty, surely they should do that for you. If there was a serious fault, I guess the warning light would be on but there are many sensors involved (wheels, pedals, etc.) so perhaps one of those is suspect.
FATBOYFIN wrote:I have to have a 135 with ABS I drive it often through France and Spain somtimes not braking from one fuel stop to the next on the motorways but I have never felt anything that you describe only ever smooth and proper braking, the only time I feel the ABS cut in other than when it should is if I brake while on full lock I feel it pulsing then but I was told this was normal, hope this helps
STEVE P wrote:Any way I had replaced the Front tyres before the fault appeard and was going to replace the rears a couple of months later as they were not as warn.
Replaced the rears as planned and the problem disapeared.
My conclusin is the ABS conputer is to sensative and the differance in wheel speed front to back is enough to lock the pedal for some reason.
STEVE P wrote:Could be. I told my local Stealer how I had fixed it and he just shrugged his shoulders.
When I asked if the sensativaty could be turned down on the ABS he just said NO!
I am sure these dealers prefer not to get involved in proper investigation stuff these days, they are happy to replace a widget of whatever but when it comes down to some proper ''lets see if we can fix it'' the are not interested.
Steve P
detroitmusclevan wrote:Steve,
I think you may be a genius.
Agreed on that!foggyred wrote:well what can i say this site is just fantastic
Users browsing this forum: smileONwheels, STEVE P
