Started On Miss Piggy
Re: Started On Miss Piggy
Postby greek » Tue Jul 28, 2009 8:28 pm
Got my door done today took door off cut all the rusty bits out
Do`nt laugh at me welding Iv`e only got an old stick electric welder so just tacked a new bit of galv in
Job Done
Probably end up with a few rust spots back through by the time i get to paint it :)
I`m to old to lie under Transits
greek
Postby greek » Tue Jul 28, 2009 8:38 pm
Anybody want any smoke damaged camping gear :( :(
greek
Postby greek » Sat Aug 01, 2009 9:49 pm
Did the gutter above passenger door today decided to cut it out & make a new one plus part of the windscreen pillar needed a bit of steel in so easier to do cutting it all out.
New bit tacked in
Bit of bodge on
Never got it rubbed down properly but had to stick a bit of primer on because it will be standing out a few days till i can get it finished
greek
Postby MinorMatt » Sat Aug 01, 2009 10:02 pm
That A post repair looks fantastic 8)
Postby greek » Sat Aug 01, 2009 10:17 pm
Thanks Matt, a lot of ametures on here me being one of them but we all seem to enjoy what we are doing.
Do you show the old Morris :?:
greek
Postby MinorMatt » Sat Aug 01, 2009 10:20 pm
Its hardly showworthy :lol:
You seen the pics of my van? The minor is worse :shock:
Postby Nadjenka » Sat Aug 01, 2009 10:26 pm
I see now! :D That's some great work there! 8)
Nadjenka
Postby madmark » Sun Aug 02, 2009 1:57 am
MinorMatt wrote:Its hardly showworthy :lol:
:shock: :shock: :shock: :shock: :shock: :lol: :lol: :lol: :lol: :lol:
Postby greek » Fri Aug 21, 2009 8:45 pm
Got a bit more done last couple of days took bonnet off lots of rust underneath on front end it was all fiberglassed so pulled that off welded a couple bits in underneath plenty of bodge made afew holes in the front where the worst rust was bodge in there then hours of rubbing down to get an edge & the right shape One more job done
Last bit of rust to do is bottom of drivers door which isn`t to bad but don`t know when loads of other things on the go
greek
Postby madmark » Sat Aug 22, 2009 5:20 am
looking good mate comeing on a treat! 8)
Postby greek » Sun Nov 15, 2009 9:04 pm
Not done much latley fixed front sidelight wires burnt out brakelight fixed.Started big time with the inside needs some of the frame sorting took a lot of the furniture out needs some new panels on the walls going to reposition the cooker & add some draws & a small cuboard which I salvaged from me old van, needs 1 new inside roof panel & all the white paint removing from all over the place just doing a bit at a time whenever I feel like it no targets but hope to have it back on the road by spring.
greek
Postby greek » Mon Feb 08, 2010 2:40 pm
Previous owner askiing how things are going SLOW is the word Geof what with weather & other things I would love to be able to crack on. Next few weeks might get to do something been cleaning a bit paint off inside put some new bits of woodwork on inside frame got the top back roof panel to put back on & trim resealed. Have got most of the furniture out to reset in the way my old one was with some of the reclaimed bits out of my old one that took a lot of work cleaning smoke & water damage still not quite there but reasonably pleased how its starting to look. Wifey has reupholsterd drivers seat & once I get new back roof panel & side panels inside things should start to move on a bit quicker
greek
Postby Southerner » Mon Feb 08, 2010 8:28 pm
Very nice job with the upholstery, I'm going to need to get my two front seats done at some point but I think I'll be going somewhere professional to get a job like yours. Andy.
Southerner
Postby greek » Tue Feb 09, 2010 3:09 pm
It`s not to hard to do yourself andy, depends what you want doing just need an old sewing machine with a bit stonger needle cut your old bits out sew new ones back in. Them old transit seats not to bad because they are made out of about 6 sections & all we did was take the 2 knackerd ones out & replaced them with leatherete which you can buy in loads different colours at most fabric shops. Cost £3 to fix that God knows what it would have cost using an upholsterer :roll:
greek
Postby madmark » Tue Feb 09, 2010 3:19 pm
:shock: wow good to see you are getting on ok :wink: the seats cost a good £300 to get recoverd :wink:
is there any other body panels you need as sixwheel phill is scrapping one very soon? there isnt much left of it tho :shock:
