Luke wrote:ok pas pump - the 3x 13mm bolts on the pulley undo them then the long bolt you'l then be able to see..... undo that - the pump will come away leaving the bracket - you can leave the bracket on but dont throw it incase the new engine is non pas) just tie the pump up to the side of the engine bay so it's not straining the pipes and wont get damaged
Luke wrote:yeah thats it- i was just trying to be helpfull so you'd get the right spanner
once its off you'lll see the long bolt - same spanner (well 2 of them) undo it
fastmower wrote:I remember that getting the manifold bolts all undone can be a fairly big pain in the ass! It's generally just a case of keeping at it - sometimes you can oly get a tiny bit of a turn on a bolt and then have to turn the spanner around to get another tiny bit of a turn etc.
Luke wrote:thats the oil pressure switch
Luke wrote:you dont need the fuel pump off - leave it on![]()
have you got the pas pulley off yetas fastmower says tap it off - 180deg tap then 180 again tap repeat untill off
