Postby Luke » Sat Aug 22, 2009 7:09 pm
not sure you do need to take off the banana manifold :? have you got the radiator out and the front slam panel off (slam panel is the bit the bonnet shuts onto) :D
Postby Nadjenka » Sat Aug 22, 2009 7:22 pm
Luke wrote:not sure you do need to take off the banana manifold :? have you got the radiator out and the front slam panel off (slam panel is the bit the bonnet shuts onto) :D
Yes Luke, this is the stage I'm at... note to self and any other female users - NEVER attempt to remove the bonnet on your own. You'll damage it and just create more work for yourself! :roll:
Nadjenka
Postby markbradleyf1 » Sat Aug 22, 2009 7:35 pm
Strewth; thats alot of work Nadjenka! Fair play to you, just watch your back lifting that heavy bonnet!
Hope the vans ready for Transitmania! :)
markbradleyf1
Postby Nadjenka » Sat Aug 22, 2009 7:38 pm
markbradleyf1 wrote:Strewth; thats alot of work Nadjenka! Fair play to you, just watch your back lifting that heavy bonnet!
Thanks, it didn't seem so heavy until it landed on my foot. :roll: Just a small dent on the bonnet corner, nothing my hammer and a bit of paint can't sort out :twisted: Not so sure about Transitmania though, will see how the re-fitting goes...
Nadjenka
Postby Nadjenka » Sat Aug 22, 2009 8:10 pm
Those retaining bolts holding the downpipe are stuck. Can't get them off (talking to it and WD40 didn't help) - is there a way around it? What if I undo the whole rusty unit attached onto the engine?
And - the pump again - there is a wire at the end of it which won't come off. The bolt turnes the wole rear rather than undo itself. Is there something I'm doing wrong?
Nadjenka
Postby Luke » Sat Aug 22, 2009 8:12 pm
Nadjenka wrote:Those retaining bolts holding the downpipe are stuck. Can't get them off (talking to it and WD40 didn't help) - is there a way around it? What if I undo the whole rusty unit attached onto the engine?
thats the manifold - yeah you can undo it there :D
Postby Luke » Sat Aug 22, 2009 8:14 pm
Nadjenka wrote:And - the pump again - there is a wire at the end of it which won't come off. The bolt turnes the wole rear rather than undo itself. Is there something I'm doing wrong?
the fuel pump?? the wire will be the stop solenoid should just unplug but if you follow the wires back the whole engine loom should unplug from the van loom in 1 connection :D that way you can leave all the wires on :D
are you taking the engine out and leaving the gearbox in place :?:
Postby Nadjenka » Sat Aug 22, 2009 8:19 pm
This is what I meant - I know it's not fuel pump, but it's close to it :oops: My brain refuses to work now, sorry... And it's the black rear that spins with the bolt.
And this is the picture of what I call "downpipe" - hope I got at least this one right...
Nadjenka
Postby Nadjenka » Sat Aug 22, 2009 8:20 pm
Luke wrote:are you taking the engine out and leaving the gearbox in place :?:
Yes, for now... I don't have enough time to exchange them both.
Nadjenka
Postby Luke » Sat Aug 22, 2009 8:25 pm
Nadjenka wrote:This is what I meant - I know it's not fuel pump, but it's close to it :oops: My brain refuses to work now, sorry... And it's the black rear that spins with the bolt.
ah i see - i'd just break it off and crimp a new terminal to the wire :)
Postby Nadjenka » Sat Aug 22, 2009 9:24 pm
Done it here.
Also got quite angry with the PS mount... :evil:
And now I'm out of ideas on that pump and THIS, what is it? Does it need disconnecting? I'm sure it's something to do with fuel, but how on earth am I supposed to get there?
Nadjenka
Postby rover » Sat Aug 22, 2009 9:44 pm
YOu do need to disonnect it, its the lift pump!
There are two little tabs on each pipe, just squeeze them and pull the pipe at the same time, they come off dead easy :D
Rover.
rover
Postby Wildy » Sat Aug 22, 2009 9:45 pm
Having just pulled a banana engine out of a mk5 this evening:
Yes it is possible to remove complete with the manifolds/pump/gearbox attatched
and that last picture is the lift pump that draws fuel up from the tank and supplys it to the high pressure pump.
Some people are like slinkies, not really good for anything
but they bring a smile to your face when pushed down the stairs.
Wildy
Postby Nadjenka » Sat Aug 22, 2009 9:51 pm
Thanks guys! And what about the fuel filter. Haynes says to "disconnect the fuel pipes at the fuel filter) do they mean where they come out of the filter or at the back - where they go in? I'm completely lost here. Wildy - did you take any pictures by any chance? :oops:
Nadjenka
