overdrive
overdrive
Postby hodgson4711 » Sat Aug 22, 2009 12:38 am
hi, can an overdrive unit from a mk2 4 speed g/box fit a mk1 gearbox?
hodgson4711
Re: overdrive
Postby madmark » Sat Aug 22, 2009 5:16 am
you need to use the mk2 gearbox :wink:
Re: overdrive
Postby rottie_007 » Sun Aug 23, 2009 9:55 pm
yeah you need the whole gearbox really as there is a bit machined onto the mainshaft to drive the oil pump of the overdrive unit..
good convertion thogh,I love my overdrive gearbox in the mk2, especailly with the york motor as it gives me some more rations to get it going and keep it moving
1979 mk2 pre facelift CI campervan " Bessie Brown "
1994 Pug 405 est " George "
1998 pug 106 "Mildred"
rottie_007
Re: overdrive
Postby baconsdozen » Mon Aug 24, 2009 7:49 am
There is a firm in the Uk that manufactures a 'universal' overdrive.The prop is cut and the unit inserted in it somehow.
An internet search using google might find them,I can't recall any other details.
baconsdozen
Re: overdrive
Postby manandvan » Mon Sep 07, 2009 11:56 pm
what engine is in your van?? if its the original v4 then you could use the mk2 overdrive box,s overdrive and mainshaft to convert yours, the input shafts are 2 different lenghts short= v4 17/2.0 and long =ohc/v6/york 2.4/ 2.5d
also the gearsets are different in size and ratio but they will all fit on either overdrive or normal mainshaft, ive rebuilt many of these gearboxes.
manandvan
Return to Mk 1 & 2
cron
