Transit cosworth flywheel/ clutch info
Postby cossierevhead » Thu Sep 10, 2009 6:07 pm
Eventually got round to takin standard engine out o my van and was hopin to use the flywheel and clutch from the dohc 2.0 on my cosworth engine but flywheel has 6 bolt fixin instead of cosworth 9 bolt fixin, so am now thinkin of using cosworth flywheel and clutch as the clutch fits on transit gearbox splines, the van is a V reg 2.0 dohc, the cosworth flywheel is slightly bigger than the transit one so wich starter etc would i use, any info would be great, cheers
Id rather push my Ford than drive a Vauxhall
cossierevhead
Re: Transit cosworth flywheel/ clutch info
Postby Luke » Thu Sep 10, 2009 7:45 pm
what i did was cossy flywheel and clutch on the tranny DOHC box (mine was a mk6 but there cant be much difference) - the inside of the bellhousing needed a tiny bit of grinding to stop it jamming on the webs :D
but the starter - ive not sorted yet i cant remmeber which one i used but it only picks up on 1 bolt i plan to make an adapter bracket to hold in place properly - but we dont really use the cossy van much so we havent got round to it yet :D
Postby cossierevhead » Thu Sep 10, 2009 8:56 pm
ive just been readin your progress reports on ur mk6 cossie van Luke and you said you had to use washers to space somethin out on flywheel???? what was that for? so if i use cosworth flywheel and clutch, grind a bit off inside of gearbox then it should mate up ok? cheers for ur help buddy
cossierevhead
Postby cossierevhead » Thu Sep 10, 2009 9:07 pm
My clutch is a cable operated, not hydraulic, will the transit release bearin come far enough forward to work the cosworth clutch? or will the clutch arm on transit box need space forward? 8)
cossierevhead
Postby Luke » Fri Sep 11, 2009 9:47 am
hmmmm ............ cant remember what i spaced out with washers it might have been to take account of the plate inbetween the bellhousing and block without actually fitting it :D
i'd forgot yours will be cable - proberbly the best thing to do would be to try it - but you will know before you do that the bolt pitch is identical - just see how far the release arm moves and if it needs it mod it - mabe even get another arm and weld the centre bit on top of the other arm so the bearing fits in the mount but is just further forward - just an easy way of doing it :idea: but i'd try it on 1st :D
anyway how about a progress report ......... WITH PICS :mrgreen: :mrgreen: :lol:
Postby danSankey » Sat Sep 12, 2009 11:58 am
will the parts off a pinto transit not fit streight on to the cosworth engine to fit it in?
danSankey
Postby cossierevhead » Sat Sep 12, 2009 10:32 pm
i was gona make a set of mounts but got told to get pinto mk3 or 4 mounts and mount bracket to bolt onto body, anybody know? ive got all the metal to make mounts and got huge welder lol. as for flywheel i think the pinto has a 6 bolt crank instead of 9 bolt cossie crank where flywheel bolts on, just gona use cossie flywheel and clutch and modify gearbox with a grinder so flywheel clears, 2mrws job lol :D :D :D :D :D
cossierevhead
Postby bikemad » Sat Sep 12, 2009 10:37 pm
why dont you just use the cossy gearbox and just mod the prop and cradle :?: :wink:
bikemad
Cosworth Powered
Cosworth Powered
Postby cossierevhead » Sat Sep 12, 2009 10:50 pm
just dont have the cash for a cossie box the now plus i just had to buy a box for my 2wd sierra cosworth lol torture :twisted: :twisted:
cossierevhead
Postby Luke » Sun Sep 13, 2009 10:28 am
just use mk3/4 pinto mounts but you'll need the chassis part to fit too :D not strait forward but the easyest way imo
also why not use a transit Di mt75 and a pinto adapterplate and clutch flywheel etc. - thats the way i'd do it over a dohc box :D
Postby cossierevhead » Mon Sep 14, 2009 2:31 pm
Luke wrote:just use mk3/4 pinto mounts but you'll need the chassis part to fit too :D not strait forward but the easyest way imo
does anybody on here have mk3/4 pinto mounts and chassis part? whats the diference between petrol and diesel box?
cossierevhead
Postby Luke » Tue Sep 15, 2009 9:07 pm
cossierevhead wrote:whats the diference between petrol and diesel box?
mabe ratios - but both will fit :D
