Yellow pages, suppliers with parts for the "A" series
Ford A-series 1974 - 1982
Postby sven » Tue Jun 09, 2009 10:44 pm
In addition to Ebay, there is a few companies which provides new or refurbished parts... Post them here
gaskets for the 3.5 litre york http://www.gasketsforclassics.co.uk/classiccomm.html
pistonrings for the york http://www.hamenz.com/models/FORD.htm (allmost in the bottom are the 0509 engine these rings will fit the 2.4 and 3.5 york
-nelson stokes in camelford cornwall can make up flexible rubber brake hoses to pattern(can anyone help with contact info?)
sven
Re: Yellow pages, suppliers with parts for the "A" series
Postby luis.sousa.6 » Mon Sep 14, 2009 7:30 pm
Hello!
In the previous aseries forum there was a website were parts were sold (brake pumps , etc), can anyone tell me the link?
Thank you!
luis.sousa.6
Postby sven » Sun Sep 20, 2009 7:43 pm
This thread has the most info on where to get parts, the contact info on the brakes are removed becauce they dont make them anymore, sorry mate...
sven
Postby luis.sousa.6 » Sun Feb 27, 2011 12:30 am
Hi, the link for the gaskets is no longer working, can anyone tell me wher to find gaskets for the 3.5 diesel for a A409?
Thank you!
luis.sousa.6
Postby sven » Mon Feb 28, 2011 1:21 am
try sending an email to: gasketsforclassics(a)tiscali.co.uk. their site is down, but they are still in business.
I purchased the top and bottom end kits there for one and a half month ago
sven
Postby FFXIII » Mon May 02, 2011 2:58 am
`My thanks also. A friend who happens to be needing a lot of parts after a flood will need this. I'll email the link.
Rank your car forums, car blogsite or car e-commerce site with automotive seo, the experts in automotive domains
FFXIII
Postby emlclcy » Sun Jun 07, 2020 9:51 pm
sven wrote:try sending an email to: gasketsforclassics(a)tiscali.co.uk. their site is down, but they are still in business.
where do you get oversize pistons valves, stuff like that from? mine only just starts with easystart so contemplating a full rebuild
cheers
carl
emlclcy
Postby nadab_sardar » Thu Oct 15, 2026 12:30 pm
Worth knowing before you commit to a full rebuild: the 3.5 York is a tough old lump, and a hard-starting engine that only fires on Easy Start doesn't always mean worn bores. Do a compression test first. If it's low on all cylinders, then sure, strip it, but low compression on just one or two could be valves or a tired head gasket, which is a much cheaper fix.
For oversize pistons, a decent engine reconditioner is usually your best bet. A lot of them can source or re-make pistons and valves for old Ford diesels, and they'll bore and hone the block while they're at it. Ring and piston sets are listed under the 0509 engine reference (same one Sven mentioned for the rings), so quote that when you're asking around. Worth also asking the A-series owners' club or posting your engine number here, as someone will probably know who has NOS pistons sitting on a shelf.
areas that mostly tyre fitting company don't cover in uk.
nadab_sardar
Return to Ford A-Series
