steel bulkhead
steel bulkhead
Postby Mark 17 » Fri May 19, 2006 12:36 am
:D does anyone know if the steel bulkhead in my ex BT mk5 N reg will fit in a mk6 :?:
Looked at loads of X, Y & onwards models but not yet seen any with this type of bulkhead fitted, so wanted to know if I could 'transplant' my old one.
Nostalgia 'aint what it used to be.
Mark 17
Postby gemini » Fri May 19, 2006 9:21 am
i dont think they do
gemini
Postby madvanman » Fri May 19, 2006 9:55 am
if you steel bukhead is the original ford one you should be able to make it fit but it wont be an easy bolt in job, you will need to make your own brackets and top part to match you vans shape.
madvanman
Customised!!
Postby Luke » Fri May 19, 2006 12:29 pm
they are quite different - true you could make it fit but for the hassle involved personally (and i dont mind hassle :lol: ) i'd buy a mk6 one!!
my local commercial breakers sells them for £40 but he never has any in! we paid £60 ish off ebay for one, but same old story once we had one they were all coming up closer and for less :roll: :lol:
Postby AndyG » Fri May 19, 2006 12:38 pm
They are definately different 'cause the mk6 has got a moulded section for the drivers seat which also makes the the baulkhead handed :!:
Postby Luke » Fri May 19, 2006 12:57 pm
and also you will need 12 i think :? captive nuts :!: - cos yours wont have them - and you need to move the passangers seat forward to the front mountings so you will need a torx bit :D
ta
Postby Mark 17 » Sat May 20, 2006 9:54 pm
well - sounds like a right load of messing so for £60 I'll get a mk6 bulkhead.
Thanks for all your reps - very much appr. :D :wink:
Mark 17
Postby motorwise » Sat May 20, 2006 10:01 pm
cast an eye over e bay - there were a couple of late bulkheads on there recently
http://www.motorwise.net
motorwise
Postby Worcestermick » Wed Jun 07, 2006 11:56 pm
I have a new 06 reg transit SWB 280 and I'm going to remove the steel bulkhead.
If you want it let me know.
Mick
Worcestermick
