does your gearstick shake!!!
Postby matthew » Sun May 21, 2006 3:09 pm
it may be a daft question but when sat idle and you put your hand on the gearstick does it shake. is this normal and when your in a gear you can feel the gearstick shaking but only slightly.
matthew
Postby xbox360 » Sun May 21, 2006 7:32 pm
My gear lever dont shake.It vibrates a little bit, but not much. Have you checked the oil level.
xbox360
Postby gemini » Sun May 21, 2006 7:55 pm
its not the oil level its when the engine is vibrating what does it
gemini
Postby Suggs » Sun May 21, 2006 8:24 pm
maybe ticking over a bit slow?, if you turn the engine off then start up again does it still do it ..
Suggs
Postby matthew » Mon May 22, 2006 3:34 pm
thinking about it does only vibrate not shake which i thought was down to the engine moving which is normal then in which case nothing to worry about.
Matt
matthew
Postby sspeeedy » Sun Jul 16, 2006 10:20 am
Does it rattle. Ford did a recall on this and replaced the gear stick.
sspeeedy
Postby Lee J » Mon Jul 17, 2006 9:45 am
mine rattles when Im driving in gears 1-4 but not 5. If i put my hand on it it stops. It also has lots of play. I can move it side to side by about 6 inch and it feels floppy.
Transit Van - Gonna cost me a marriage if I'm not careful.
Lee J
Postby catdaddy » Mon Jul 17, 2006 9:42 pm
my stick stays perfectly still.the van shakes like F**k though :shock: :shock: :shock:
catdaddy
Party Animal
Postby motorwise » Mon Jul 17, 2006 9:55 pm
catdaddy wrote:my stick stays perfectly still.the van shakes like F**k though :shock: :shock: :shock:
:lol: :lol: like it :lol: :lol:
http://www.motorwise.net
motorwise
Postby Nighthawk » Mon Jul 17, 2006 10:00 pm
sspeeedy wrote:Does it rattle. Ford did a recall on this and replaced the gear stick.
Did they/we?
I must have missed that.
What vehicle are we talking about here?
Transit.........Job done
Nighthawk
Postby sspeeedy » Thu Jul 20, 2006 2:42 pm
Mines on O2 plate and they changed mine for me.
sspeeedy
Postby madmark » Thu Jul 20, 2006 2:54 pm
:) mine seems ok! at the moement! :wink:
Postby Nighthawk » Thu Jul 20, 2006 8:44 pm
sspeeedy wrote:Mines on O2 plate and they changed mine for me.
A dealer replaced the upper gear stick for you due to a vibration.
Two places of vibration/tizz in the upper stick are the top gear position plaque and the retaining clip at the base.
A more common one would be the O ring on the top of the stub shaft allowing the upper lever tizz against the stub.
None of which have been subject to a Service action/recall or even a TSB
Nighthawk
