electrics
electrics
Postby wendy » Thu Sep 24, 2009 1:36 pm
hi
ny son installed some cams yesterday. all worked well til i was heading home. an hour into the journey, the monitor went off. when almost home, the lights inc indicators and inner van lights stopped working. i got home, turned off the ignition and then tried to restart the van...nothing.
my thoughts were theres a short somewhere but as i know next to nothing about vehicles and electrics, i would prob be wrong.
PLEASE HELP!
wendy
Re: electrics
Postby AndyG » Thu Sep 24, 2009 1:39 pm
:idea: Battery not charging :?:
Did you have ign. and oil lights come on when you started up :?:
Re: electrics
Postby wendy » Thu Sep 24, 2009 1:49 pm
dont think those lights were on when i put ignition on.
the battery was fine before, so i guess the cameras have something to do with it??
whats draining the battery?
why isnt it charging as before?
what do i need to do to put it right, based on the fact i dont know what im doing?
wendy
Re: electrics
Postby AndyG » Thu Sep 24, 2009 1:50 pm
:o How many cameras :?:
Might be just a fuse :idea:
Re: electrics
Postby wendy » Thu Sep 24, 2009 2:07 pm
3 cams
rear and sides.
would a blown fuse drain the battery?
wendy
Re: electrics
Postby jls security » Thu Sep 24, 2009 3:54 pm
wendy wrote:3 cams
rear and sides.
A blown fuse wouldnt drain the battery. The first thing to do is go back over the installation of the cameras and check everything you have done. If it is related to the installation then it should become obvious as you trace back the work.
It is hard to say without actually looking at the vehicle as to what might of happened.
www.jls-security.co.uk. If i can help I will, just ask!
Vehicle security/Hands free/Van Locks/Tracker/Parking systems
jls security
Re: electrics
Postby AndyG » Fri Sep 25, 2009 12:03 am
If it's the ign. fuse, then yes :!: As the battery will NOT be getting charged when you are running the van :!:
Re: electrics
Postby sidspop » Fri Sep 25, 2009 4:16 am
What age of van is it? May be relevant
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Re: electrics
Postby wendy » Fri Sep 25, 2009 7:33 am
its 1995
wendy
Re: electrics
Postby AndyG » Fri Sep 25, 2009 11:41 pm
:idea: If the battery was disconnected to carry out the camera work, it wouldn't be the first time one of the smaller cables attached to the battery post ave been left off :?:
Re: electrics
Postby wendy » Sun Sep 27, 2009 12:59 pm
the batteries connections are fine. i disconnected all cables and its made no difference.
jump started the van, went for a ride round. stopped to get fuel and had to jump start again.
do u think this is coincidence or connected to the cam situation?
i feel helpless cos i dont know what to do to put it right. grrrrr :twisted:
wendy
Re: electrics
Postby AndyG » Sun Sep 27, 2009 2:18 pm
wendy wrote:dont think those lights were on when i put ignition on.
No lights = no charge :!:
Check your fuses and ign relay :idea:
Re: electrics
Postby wendy » Sun Sep 27, 2009 4:19 pm
when i turn the ignition, it just clunks, doesnt try to start engine.
what is ignition relay?
wendy
Re: electrics
Postby Nadjenka » Sun Sep 27, 2009 4:32 pm
Wendy, I'm no expert, but with my woman logic I would do following:
1. Make sure all the wires are correctly connected onto the battery
2. Check the main connection socket is connected properly (ehm... not sure what is it called - the big one you see on the main wire coming from the battery)
3. Check all the fuses are in working order and plugged in
4. If no fault found until this point, I would charge up the battery with a charger and try running it again OR take the battery to be tested by professional (might be that the battery is old/lacks liquid OR is just not able to be recharged)
5. If none of the above works, it might be the alternator not functioning properly, but wouldn't this show on the dashboard warning light??? Someone? :?
I would think it is the battery, simply because they could have drained the battery to minimum whils installing the cameras and being too old, battery just doesn't charge up anymore. Again - I'm no expert, but I would think this might be the case. Try charging it with a charger to full and see what happens. Not sure how much the garage charges to check if the battery is working... :? Hope you resolve it soon, let us know! :wink:
Nadjenka
Re: electrics
Postby Nadjenka » Sun Sep 27, 2009 4:45 pm
Right, I would have to tell you to get a Haynes manual, but here is the information about relays:
Relays and timers are located in the central electric box (the one under the dashboard next to your right foot when sitting behind the wheel). If a system controlled by a relay becomes inoperative and the realy is suspect, listen to the relay as the circuit is operated. If the relay is functioning, it should be possible to hear it click as it is energised. If the relay proves satisfactory, the fault lies within the components or wiring of the system. If the relay is not being energised, then it is not receiving a main supply voltage or a switching voltage, or the relay is faulty.
Now someone correct me if I'm wrong: does this mean that if a ignition relay is faulty, and your battery is charged up, once you turn the ignition you should hear the relay click? OR - when you remove the relay and connect multimeter there, you should see the power going in? Will this determinate wether it is the realy OR the wiring? Is there any other sensible way how to test the relay apart from "listening to it"??? :?: :?
Nadjenka
