yes try the one going into the back of the speedo - right in the centre should just push forward - may have just come out and only be touching a bit!!!Aleka wrote:Could it be a loose cable somewhere?
if its been stood for a while it should get better with some use - your (very small) problem is most likely to be carb related i wouldnt worry too much about dirt in the tank - just dont let it run very low on petrol!! if you still have the probs give the engine a good service before doing anything serious!!Aleka wrote:Fingers crossed that's it is a loose cable then.
The transit was a bit slow the first bit of the journey home and idled fine. (It had been stood for a while)
However after we gave it a good blast it ran better and the power went up on it. However on the drive when we got it home(drive is on a slope) it was idling ok but nearly stalling you could save it with a quick blip on the accelerator.
Could this be because we've stirred up all the bits, dirt etc in the tank??
Sorry for all the questions!
Aleka wrote:
Does this help??
