Speedo and mileage bit not working properly.
Postby Aleka » Sun May 21, 2006 11:22 pm
Hi
Have just purchased a 1986 Ford Transit 190. Its actually a horse box!
But the Speedo jumps about 10 mph and clicks ocassionally. Also the mileage doesn't appear to be working!
Any ideas guys??
Aleka
Postby FredTransit » Sun May 21, 2006 11:26 pm
Welcome Aleka. It will either be a worn speedo (at the back of the speedo), or a dodgy speedo drive in the gearbox (most likely). Take the little nylon gear out of the gearbox (at the end of the sppedo cable) and take it to a spares shop (maybe not available from Ford any more). If a new speedo drive doesn't work, it will be the speedo. It will be off to the scrappie for that! Where abouts are you?
FredTransit
Mk2 Trannyist
Postby MrMPuk » Sun May 21, 2006 11:26 pm
Sounds like the speedo is knacked, either due to age or I would say someone playing with it.
Postby FredTransit » Sun May 21, 2006 11:29 pm
I think I know where you are going with this MrMp, but I don;t see the point of clocking a 20 year old transit, unless it's REALLY special and billed as a concourse model! Pic would be nice!
FredTransit
Mk2 Trannyist
Postby Aleka » Sun May 21, 2006 11:30 pm
The MOT's verify most of the mileage. It's an intermittent fault. Could it be a loose cable somewhere?
Also how difficult is it to do a basic service? It's the 2.0 ltr petrol version.
They do only have 4 gears don't they??? Can't find a 5th if there is one!
Thanks for replying so quickly!
Aleka
Postby Aleka » Sun May 21, 2006 11:33 pm
Does this help??
Aleka
Hope the pic helps. It's the only one I've got at the mo.
Aleka
Postby FredTransit » Sun May 21, 2006 11:34 pm
Is this a Mk2 (square shape) or a Mk3 (wedge shape)? Most of both were 4 speed, but if she has been converted to or has 5 speed from original (unlikely, as you can only find 4 gears!), the speedo drive could be off (with a conversion). As Mr MMp says, it sounds like a worn speedo, in which case look for a second hand one.
FredTransit
Mk2 Trannyist
Postby Luke » Sun May 21, 2006 11:35 pm
Aleka wrote:Could it be a loose cable somewhere?
yes try the one going into the back of the speedo - right in the centre should just push forward - may have just come out and only be touching a bit!!! :D
Postby Aleka » Sun May 21, 2006 11:42 pm
Fingers crossed that's it is a loose cable then.
The transit was a bit slow the first bit of the journey home and idled fine. (It had been stood for a while)
However after we gave it a good blast it ran better and the power went up on it. However on the drive when we got it home(drive is on a slope) it was idling ok but nearly stalling you could save it with a quick blip on the accelerator.
Could this be because we've stirred up all the bits, dirt etc in the tank??
Sorry for all the questions! :P
Aleka
Postby Luke » Sun May 21, 2006 11:53 pm
Aleka wrote:Fingers crossed that's it is a loose cable then.
if its been stood for a while it should get better with some use - your (very small) problem is most likely to be carb related i wouldnt worry too much about dirt in the tank - just dont let it run very low on petrol!! if you still have the probs give the engine a good service before doing anything serious!!
and you can turn the tickover up if it keeps cutting out!
:D
Postby FredTransit » Mon May 22, 2006 12:05 am
Aleka wrote:Image
Does this help??
It's a Mk3 then! Must be really early. Try getting some carb cleaner from a spares and accessories shop, and give it shot. It might clear the jets.
FredTransit
Mk2 Trannyist
Postby rover » Mon May 22, 2006 8:23 am
You still dont say where you are Aleka...
If you are local to me I have a speedo you can have!
Servicing doesnt come easier than a Pinto engine, so you shouldnt have too many probs.
Rover.
rover
Postby Aleka » Mon May 22, 2006 9:43 am
Hi
Sorry am based in Oxfordshire.
Is there any kind of manual ie Haynes that I can get to help me with a basic service??
I'm not great when it comes to things like this!
Aleka
Postby FredTransit » Mon May 22, 2006 11:24 am
Do a site search mate, I believe Gunslinger has uploaded the manuals for downloading, and put up the links on this site.
FredTransit
Mk2 Trannyist
