Nealry bought a transit
Postby Burgerking » Tue May 23, 2006 9:07 pm
hi
not got a transit yet.........looking at one. it's R reg 80 swb normal roof. it's clean and going for about £1100. 1 month tax & 12 months mot, 101000 miles on clock, cam belt done 90000.
what mpg would this van do, and what problems should i be aware of...
need some good pointers/advice coz i run a ford escort van R reg and i need to make the jump to the tranny, plus i can get more work for my courier business
cheers
wayne
http://www.mwcourierservice.co.uk
Burgerking
Postby AndyG » Tue May 23, 2006 9:14 pm
Rust is the only thing to worry about :!: Check those front and rear wheel arches carefully :!: Take a small magnet with you :!:
Have a general look underneath for corrosion :!:
If you have a look under Members Transits Progress Reports you will see all the weak spots uncovered :D :lol:
Re: Nealry bought a transit
Postby Luke » Tue May 23, 2006 9:21 pm
Burgerking wrote:what mpg would this van do
well my mk4 swb 100 has just done 33mpg have a read through the mpg thread in transit talk :!:
Postby Burgerking » Tue May 23, 2006 9:28 pm
wot does the 80 mean on the tranny ??
Burgerking
Postby Luke » Tue May 23, 2006 9:31 pm
Burgerking wrote:wot does the 80 mean on the tranny ??
load capacity in kg 80 = 800 kg or thereabouts 100 = 1000kg and 120 = 1200kg, 150=1500kg 190 = 1900kg
150 is the maximum in swb but as it has the 6 stud axles it has the low ratio diff so it aint no motorway cruiser!! :D
