clutch pedal
clutch pedal
Postby 100ps_drw_hicube » Thu May 25, 2006 9:06 pm
:roll: :roll: anyone got any idea when at 4000+ rpm my clutch pedal vibrates up and down :? :? :? really annoying me now :x
100ps_drw_hicube
Transit Abuser!!
Re: clutch pedal
Postby AndyG » Thu May 25, 2006 9:09 pm
100ps_drw_hicube wrote::roll: :roll: anyone got any idea when at 4000+ rpm my clutch pedal vibrates up and down :? :? :? really annoying me now :x
:shock: What do you mean :shock: :lol: :lol:
Your engine won't last long if you keep doing that :(
Postby 100ps_drw_hicube » Thu May 25, 2006 9:14 pm
:lol: :lol: :lol: mate they are meant to rev to 4200rpm arent they?? :? anyway what i mean is at about 95mph the clutch pedal literally jumps up and down violently between the slack and gets very annoying
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Thu May 25, 2006 9:23 pm
Your max. continuous revs is supposed to be 4000rpm and it says 4400rpm intermittently :shock:
Mine went over this once and frightened me :shock:
Back to your problem. Is there a soft spring you could have left off :?:
Is the pedal loose :?: and at what rev does this start :?:
Postby 100ps_drw_hicube » Thu May 25, 2006 9:27 pm
no springs missing that i can see starts at 3900rpm on only in 5th tho but i rarely thrash her in other gears i think the police have had the governer fiddled with :? :? it has always revved to 4300rpm ish continuously :?
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Thu May 25, 2006 9:28 pm
Clutch alingment?
Postby Luke » Thu May 25, 2006 9:30 pm
strange one :? how bad is it :?: if you put your foot on it lightly does it stop :?:
Postby 100ps_drw_hicube » Thu May 25, 2006 9:31 pm
i used the correct tool which is far better than the s**t they sell today plastic crap :x should be ok but worth a check i suppose :? :roll:
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Thu May 25, 2006 9:33 pm
Didn't it do this before :?:
Don't you think you're being a bit harsh (alright lets be honest) very harsh on your engine :?: :lol: :lol: :lol:
And 3900rpm is high enough :shock: :lol:
It's not a sports car :oops: :lol:
Postby 100ps_drw_hicube » Thu May 25, 2006 9:35 pm
no never done it before yes probably a bit harsh but jobs to be done etc etc :roll: :roll: :roll:
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Thu May 25, 2006 9:40 pm
Could the pressure plate be comming lose :shock: :?:
Postby 100ps_drw_hicube » Thu May 25, 2006 9:42 pm
great gets better now :roll: will look into it asap then!!! it was torqued up tho
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Thu May 25, 2006 9:44 pm
How many lbs :?:
Could the faulty clutch (you first tried to fit)have ruined the threads :?:
Postby Luke » Thu May 25, 2006 9:46 pm
i wouldnt have thought the pressure plate is coming loose - does the clutch slip at all :?:
Postby WINDSCREENGUY » Thu May 25, 2006 9:46 pm
mine revs to 4200 as well but can only get 85mph from mine :(
formally grey van man.
WINDSCREENGUY
previously grey van man
