MOt advisory points - advice sought
Postby rhb » Fri Oct 30, 2009 1:38 pm
Hello,
Just passed MOT with a number of advisories, just after details (what consequence of not fixing, priority of dealing with, ease of DIY for someone more used to working on push bikes and rough ballpark prices to expect at garage if anyone is in the know) for correcting the following..
Front Rusty Brake discs slightly pitted 3.5.1h
Exhaust partly deteriorated 7.1.1.a
Nearside front steering rack gaiter deteriorated 2.2.D.1d
Front coil spring corroded (both sides) 2.4.C.1b
Rusty battery tray (I think this one is the easiest?!)
Bothe side front inner wing under bonnet rusty
vehicle underside showing signs of surface rust (it's 19 years old so surely to be expected? tho it wasn't noted last year)
Oil leak from engine (not noticed any spots where it's parked for 2 weeks plus at a time, but if they say so...)
Any advice much appreciated, I'm still a total klutz on these things.
rhb
Re: MOt advisory points - advice sought
Postby ME » Fri Oct 30, 2009 4:45 pm
It passed so nothing is classed as serious or defective.
The battery tray is a wire brush and Hammerite job DIY .
As for the rest how much would you want to pay out on a 19 year old van for advisory work ?
I'd leave it till next year :lol:
Mercedes Vimto Premium
ME
Postby dumper » Fri Oct 30, 2009 6:57 pm
me to but i would spray the under side with wast oil to help proteck a bit
Postby foggy08 » Fri Oct 30, 2009 7:00 pm
not bad mine failed last time for having shakey mirrors....thats all
ouch ..suarez bit my finger
foggy08
Postby dumper » Fri Oct 30, 2009 9:52 pm
tester takeing the p what
Postby rhb » Mon Nov 02, 2009 8:58 pm
Thanks, got a friend looking into it to. I understand it's not essential, prevention better than cure though?
rhb
Postby xleox » Thu Nov 05, 2009 2:05 pm
dumper wrote:me to but i would spray the under side with wast oil to help proteck a bit
do you mean old chip fat? or is 'wast' oil something particular?
xTHE VANx - making Britain seem smaller
xleox
Postby trevor3839 » Thu Nov 05, 2009 5:10 pm
Take it you won't be parking your van on any customers drives then?
trevor3839
Postby rhb » Thu May 20, 2010 9:18 pm
Battery tray as referred too above needs replacing. Can anyone please recommend a good dealer in w.mids for these sort of bits? Mk3 t100
rhb
Postby MinorMatt » Thu May 20, 2010 9:36 pm
So what? Leave it and you will probably find the pitting has gone next year
Have a look - you don't want it to break off - exhausts arn't that expensive
I would replace that sooner rather than later tbh
Investigate - if it looks like there is anything more than serious rust replace em before they break!
If the battery is secure dont worry about it - if not you can get new ones. (if its a drivers side tray I have a good used one here)
I wouldn't worry about it too much - its not going to cause anything to fail
If you dont want to do any welding next year, get a wire brush on an angle grinder clean it off as best you can and paint it
I wouldnt worry about this if it doesnt seem to be losing any or leaving spots
Postby rhb » Mon May 24, 2010 5:37 pm
MinorMatt wrote:Front Rusty Brake discs slightly pitted 3.5.1h
Thanks for these pointers.
Any suggestion on what the Haynes manual would call a steering gaiter and front coil spring. Neither mentioned in my copy.
Battery tray is no longer secure, it is passenger side. Wondering where best to shop for one in mids, or online. Any recommendations?
rhb
Postby Ollie » Fri May 28, 2010 10:43 pm
You used to be able to get them as a standard item from panel suppliers, try Discount body panels on the Warwick road in Birmingham or alternatively get a cordless drill and drill out the spot welds on some old knacker in a breakers yard! failing that get some bungee cords and do what everyone else seems to do! incidentally, is it the tray or the fixing for the securing bar which has gone? penny washers spring to mind.
The MOT tester is just covering his butt with some of that, but some of it like the steering rack gaitors are def worth a look - Matts assesment is pretty much spot on.
Ollie
Ollie
