brakes binding, one front wheel only, intermittent
Re: brakes binding, one front wheel only, intermittent
Postby bigjohnthomas » Tue Nov 17, 2009 10:20 pm
duel circuit brakes they have these days u know 2 lines to the rear axle . rubbery ones are more expensive than that arnt they? :?
bigjohnthomas
Postby winterheating » Tue Nov 17, 2009 10:27 pm
i think of the top of me head youd need 4 at rear axle either side of the LAV.
winterheating
Postby bigjohnthomas » Tue Nov 17, 2009 10:34 pm
so you need 6 then? :lol: i have one spare rear in my shed its 2 flexi pipes fixed into a chunk of metal at each end
bigjohnthomas
Postby dojj » Fri Nov 20, 2009 4:30 pm
you need one for each caliper, so that's 4 for starters
and if ther ear axle has one either side then that's 6 altogether
or 5 if there is only one required for the axle
dojj
Postby bigjohnthomas » Fri Nov 20, 2009 6:35 pm
mine has drums on the rear with cylinders not callipers and a rusty bit of brake pipe tiewraped to the axle going to 2 flexis to the load sensor i think :?
bigjohnthomas
Postby angie » Thu Jun 10, 2010 8:43 am
Transit mk 6 front brake sticking on.
My Transit front brake started to bind, I looked at the caliper first and because it was rusted and the rubbers perished I changed it at a cost of £85 plus brake fluid. After a couple of days it started to bind again and I lost front wheel bearing grease, melted with the heat, then I changed the flexible brake pipe £15. Now it is fine with no binding and the trouble....where the flexible brake pipe is bracketed to the suspention strut a metal bracket goes around the brake pipe, this had rusted, the rust expanded and squashed the flexible hose so hardly any internal bore was left, so when you brake it pressurises the pipe and when you release the brake the flexible pipe collapses internally keeping the pressure on, until suficiant movement of the flexible hose releases the pressure until you brake again. In hindsight an easy fix would be to cut through the bracket holding the flexible hose, to release the pressure until you got another new pipe, obviously taking care not to cut through the pipe, and keeping it out of the way of any moving parts.
angie
