snapped exhaust manifold stud
Postby OxtonyxO » Tue May 30, 2006 5:47 pm
ok taken the exhaust manifolds of the 24v and oh no
2 manifold studs snapped
one was stuck in with exhaust paste :roll:
the other i snapped :roll:
so any ideas as to how to get them out?
i have drenched them in wd40 and there is enough to get hold of them with mole grips apart from that is it just a case of drill and tap
any ideas please :?:
OxtonyxO
Postby motorwise » Tue May 30, 2006 5:50 pm
have you got a MIG welder?
http://www.motorwise.net
motorwise
Postby rover » Tue May 30, 2006 5:52 pm
Were on the same lines there Motorwise :wink:
And to save you asking Tony, if you have then you can weld another bolt to the end of whats left.
Rover.
rover
Postby motorwise » Tue May 30, 2006 5:54 pm
rover wrote:Were on the same lines there Motorwise :wink:
Rover.
great minds think alike :lol: :wink:
motorwise
Postby OxtonyxO » Tue May 30, 2006 6:01 pm
yeah i have got a mig welder but dont think my welding is that good :cry:
OxtonyxO
Postby crazyscoot » Tue May 30, 2006 6:23 pm
i Snapped a couple of studs on my car recently, got hold of a draper stud extraction set, heated up the block with blow tortch and after a bit of wrangling and swinging they came loose. Was about £10/£12 for the set, but you can only use them if you still have a stud it will grip
Negative reality inversion
crazyscoot
Postby Luke » Tue May 30, 2006 10:06 pm
i always work on the principle if the stud sheared whilst being undone then a stud extractor (the drill and exract type) wont shift it!!
another tip with the mig is rather than welding a nut to it is weld a blob on the end of the stud then cool it then weld a blob on th bolb and so on then get the stillys on it - the advantage of doing it this way is its easier to get good contact with the 1st weld if you know what i mean!!! :D
Postby rover » Wed May 31, 2006 8:44 am
And the heat from the welding tends to make them easier to shift anyway :D
Rover.
rover
Postby baconsdozen » Wed May 31, 2006 11:43 am
If the worst comes to the worst you'll have to drill it out.Starting with a small drill accurately in the centre and gradually increasing the size untill only the threads are left which can then be winkled out with a fine screwdriver or similar.Another way is to drill a series of fine holes in a line going through the centre of the stud so that the stud ends up in two halves.This needs accurate drilling,cobalt or similar drills and patience but lessens the chance of damaging threads.If a bit of the broken stud protrudes it will have to be ground flush to use eithe method.
baconsdozen
Postby madmark » Wed May 31, 2006 3:05 pm
collogne engines are prone to this happening! :?
Postby OxtonyxO » Wed May 31, 2006 6:46 pm
thanks for all the help guys
will give the welding a nut to it a try
ive got some gas/air now so will heat it a little first
if it snaps i will drill and tap it
does anyone know the thread size for the tap?
OxtonyxO
