how fast should my van go ?
Re: how fast should my van go ?
Postby jay » Thu Nov 26, 2009 9:46 am
will add most of the vans from 1990 with the 76/70ps engines will do 80-85mph but can a while to ge there and will be screaming.luton vans will do 60-70mph depending on engine power....marve might be a idea to check to make sure you have full throttle on the pump as cable might need adjusting or the engine might have had the pump turned down a bit from a previouse owner.
mk1 connect tourneo
jay
Postby kevincego » Fri Nov 27, 2009 1:07 pm
90 here 8)
2008 Transit 140 SportVan
2010 Transit SportVan Trophy
kevincego
Postby oldmadbiker » Sat Nov 28, 2009 6:43 pm
my mk 5 70 ps will do top speed of 80
i normally plod along 55/60 any more then that and its screaming too much for my liking.
i pull off in second and am thinking of bigger tyres on the back too improve gearing altho speedo
will be inaccurate.
oldmadbiker
Postby ginsambo » Sat Nov 28, 2009 7:45 pm
I take great pride in doing 55-60mph tops and take comfort in the fact that 50mph is my speed limit anyway on a national speed limit 'A' road as I'm a class 7 190 tipper. I like to wind up the 1.1 litre kids, the executives in their Beamers and the couriers in their Sprinters, although that said I am a little more sympathetic to the couriers. I watch in horror as they overtake at 80mph at the blind turns on the right hand turning space chevrons only to have me catch up with them 12 miles later in the congested 40mph zone :roll: .
60mph is the speed limit - I wouldn't worry about it.
My Mk5 was biodegradable and disintegrated with time.
Ford. Committed to the Environment
Finally entered the 21st Century and bought a MK7. Oh Dear.
ginsambo
Postby birdy » Sat Nov 28, 2009 11:01 pm
seems to be 2 distinct types of bad driver regarding speed obviously the typical white van man racing about like a lunatic not caring about other road users undertaking - swapping lanes frequently etc etc etc but the opposite type also annoy me 27mph in a 30 zone 48 mph on motorway .Dont know which i hate most .
birdy
Postby marve114 » Sun Nov 29, 2009 10:59 am
ok full service done yesterday service went ok other than we just try'd to taP the fan nut round with a chisel and it fell off :cry: :cry: :cry:
some one was on our side tho there was a lwb tranny with banana engine and we got the brake servo off that for £30 :lol:
any way van is no real difference in speed i just want to be about to cruz at 60-65mph is that so bad :)
it screams at 60 that aint no good :|
could it have a govner on it being ex british gas ?
marve114
Postby ginsambo » Sun Nov 29, 2009 6:34 pm
birdy wrote:48 mph on motorway.
Funny, I didn't see you behind me, I would have sped up. :lol: Seriously 27 in 40 zones annoys the crap out if me too. What I especially hate is when your fully loaded going up a hill and need the revs the car driver slows down whilst doing their hair or whatnot and then accelerate away towards the peak of the hill leaving you like a muppet doing 20mph up a hill with a 2 tonne trailer on a national speed limit road. :roll: Always speed up for lorries getting their speed up for the incline!
So Marve what happened to your fan? It fell off? How'd that happen? Usually you can just whack a 32mm fan spanner with a hammer and it'll eventually come loose after repeated frustrating attempts.
So is their no projecting threaded bit on the waterpump pulley? - Has it snapped? :shock: Why not fit a rad with an electric fan off a BOB scorpio or something instead or are you going to replace the waterpump.
ginsambo
Postby knighty1981 » Sun Nov 29, 2009 7:59 pm
even witha governor it shouldn;t be reving it's tits off at 60 :(
you need a gearbox or diff swap... or both
used to have an D reg tranny years ago - was the one I passed my test in actually (1999)
after an engine and gearbox swap, and then a backaxle swap.... we totaly randomly (and luckaly) ended up with a really good combination, used to do 115 flat out ;) (according to the sat nav) - on a private road of course ;)
knighty1981
Postby jay » Sun Nov 29, 2009 10:32 pm
To change your revs on a transit you can only change the back axle as the gearbox are all the same(MT75)there is a small change in the ratio spread (wide ratio and normal)which is basical a lower first and second gear...
Birdy the diffrent van drivers..The fast one has no ponits on there licence and dont care less...The one going slower has lots of points on there licence...
mk1 connect tourneo
jay
Postby marve114 » Sun Nov 29, 2009 10:56 pm
so you reckon i need a diff change ? what do you recomend ?
marve114
Postby MrMPuk » Sun Nov 29, 2009 11:00 pm
marve114 wrote:so you reckon i need a diff change ? what do you recomend ?
Nope, as I said you already have a good diff and box.
Postby Steve B » Mon Nov 30, 2009 12:11 am
your ratios are the same as mine but mine tops out at 85 so I think you may have other issues to deal with, at 60 mine sounds like its revving hard but I dont have a rev counter so dont know what the revs are, sounds like the speedo may be giving a false reading
Steve B
Postby marve114 » Mon Nov 30, 2009 9:29 am
thanks steve b 8)
made me feel a bit better i will try and get these mondeo clocks fitted that i have and see what she is revving to :wink:
my clocks dont have the wire for the rev counter my alternator has two wires on the side and a fat red one on the top
am i right in thinking its the black and grey wire i need to splice into and that its number 8 i need to put the wire into behind the rev counter
cheers
lee
marve114
Postby ginsambo » Mon Nov 30, 2009 9:32 am
If you don't have a hig spec loom, just run a wire from the middle contact of the alternator.
You can see the missing pins on your Transit clocks, I think its pin 8,9, 11 or 13 from memory.
ginsambo
Postby baxta » Mon Dec 07, 2009 7:38 pm
mostly id get 80 -85 mph with no mods , but one day it had a suden burst of power and got 95 down hill but not had it again,( somthing to do with a piston hanging out of the block)so i put in a second hand lump got 55 max (that one died too after 4 miles )
so now building a recon, 3rd time lucky fingers crossed
baxta
Users browsing this forum: AdsBot [Google]
