which battery
which battery
Postby mrmurf » Tue Dec 08, 2009 9:28 pm
hello i need to buy a nuw battery for my 1997 2.5 non turbo doe you think a 12v 63ah is up to the job thanks :!:
mrmurf
Re: witch battery
Postby Frag » Tue Dec 08, 2009 10:01 pm
Can`t remember ah but standard fit was 590A CCA,so that size or larger really.
Frag
Ford Technician
Re: witch battery
Postby mrmurf » Tue Dec 08, 2009 10:45 pm
ok thanks fella :)
mrmurf
Re: witch battery
Postby GBBiker » Tue Dec 08, 2009 10:46 pm
Standard battery model for the 2.5 Di is an 096.
It should be rated somewhere in the region of 70Ah and 680A Cold Crank.
I can recommend the Bosch S3 or S4 batteries. The S3 is the cheaper one if you are on a budget and will set you back in the region of £70 from Euro Car Parts. The S4 is a bit more pricey at around £95.
GBBiker
Wrong Again!
Re: witch battery
Postby mrmurf » Tue Dec 08, 2009 10:49 pm
thanks ill get one tomorow thank you :)
mrmurf
Re: which battery
Postby darkbluevanman » Wed Dec 09, 2009 7:59 pm
bosch was only a tenner dearer than a no brand round here, bosch silver, not sure which one..
darkbluevanman
Re: which battery
Postby birdy » Wed Dec 09, 2009 9:22 pm
If you have a manbat depot nr you they supply 4yr warranty batteries for transit less than £50
birdy
