New spots, disater
New spots, disater
Postby Philious » Wed Dec 09, 2009 8:29 am
:shock:
hey all
I have made a bo bo with my spot lights, I wired them into the the full beam without a fuse and relay staraight to neg on the battery and full beam wire :oops: they worked fine for a few hours then they went out as well as the light they were wire up to, have disconnected them but still the light I wired them into still won`t come on any ideas guys :oops:
Philious
Re: New spots, disater
Postby simplyshaker » Wed Dec 09, 2009 9:11 am
Must be the fuse (the original one for the headlights)
Unless you have blown all the bulbs !!!!
I doubt the wires will have suffered.
If your going to be a bear, be a grizzly
simplyshaker
Postby griffj » Wed Dec 09, 2009 12:34 pm
i would go with fuse for the main beam circuit.
or, you have fried the switch on the coloum, of fried the wiring, but most likely the fuse afterall you added an extra 110 Watts to the circuit!
griffj
Re: New spots, disaster
Postby Philious » Wed Dec 09, 2009 6:06 pm
I`ve checked the bulb in the other headlight and works, I`m getting the main beam lights(both) its only when I switch to full beam the one I attached the spots to goes off :shock:
is the fuse for the full beam under the steering wheel? is there a seperate fuse for each headlamp? and which fuse is it?
thanks for the help guys
Philious
Postby simplyshaker » Wed Dec 09, 2009 6:59 pm
could you have bypassed the headlight when you wired up your spot lights, and now you have taken them off, there is no power getting to the bulb ?
simplyshaker
Postby Philious » Wed Dec 09, 2009 8:37 pm
Yeah that had crossed my mind today, I used a scotch block to break into the full beam wire and thought that the wire might of severed I can`t check it until the weekend but will give it a try :)
any thoughts on the fuses?
Philious
Postby tranny mhan » Wed Dec 09, 2009 10:40 pm
Putting a straight feed to the spots from the high beam circuit puts an awful lot of strain on the HB circuit..Much better to have a relay wired into the HB circuit drawing its power direct from the battery via a 25amp fuse instead of drawing power direct from the HB circuit.
tranny mhan
Postby Philious » Thu Dec 10, 2009 4:12 pm
yes I know :cry:
I remember back in the day with my MK2 Escort and spotlights all over it wired in as I had done :roll:
I do now have the relay and inline fuse fuse ready to go on......lesson learned there.
Philious
Postby Steve B » Fri Dec 11, 2009 1:51 am
griffj wrote:i would go with fuse for the main beam circuit.
I did try to take notice of this post but I keep looking at the avatar, sorry!
Steve B
