Clutch or clutch cable?
Postby and1ne13 » Thu Dec 17, 2009 11:59 am
I recently noticed that my gear stick was harder getting into gear than normal, the clutch pedal was going down fine.
As the week went on it got worse and worse, i was half way through my day at work when boom, the clutch pedal hit the floor, i have had to get it towed to a garage..
I wanna know what the problem is because i dont want screwed by someone telling me its the whole clutch when it might just be the cable. Any help would be great, thanks Jamie.
and1ne13
Re: Clutch or clutch cable?
Postby madmark_50484 » Thu Dec 17, 2009 12:14 pm
Chances are clutch cable happened to me before (although I drove it home like it) check if the pedal just flaps around and you can check the cable as well under the bonnet see how much slack it has but that would be my guess
It is also a very easy job I done it myself took about 10 mins if that
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Postby vanfox » Thu Dec 17, 2009 12:14 pm
95% it's the cable. Reach underneath and waggle the release lever. If it's loose and the cable will pull out backwards it's the cable. They do snap, had two fail on me in 10 years. Both took a day or so to break.
Guess you've not learnt to drive without a clutch......
vanfox
Postby and1ne13 » Thu Dec 17, 2009 12:31 pm
guys thanks for the quick replys, i tried bumping it in 2nd and it drives but through edinburgh with all those traffic lights, its a no go. Im gonna get the cable changed today and ill let you know how i get on, thanks again.
and1ne13
Postby madmark_50484 » Thu Dec 17, 2009 12:49 pm
and1ne13 wrote:guys thanks for the quick replys, i tried bumping it in 2nd and it drives but through edinburgh with all those traffic lights, its a no go. Im gonna get the cable changed today and ill let you know how i get on, thanks again.
I don't blame ya using it without a clutchpedal isn't easy unless you are good at it I drove mine from basildon to southend with traffic lights.
Past
Present
www.busesuk.co.uk
madmark_50484
Postby Jackdawman » Sun Dec 20, 2009 4:14 pm
had the one on my truck snap a couple of months ago. just went with no warning.
i always carry a spare though, 10 mins later i was mobile again.
Jackdawman
Postby birdy » Mon Dec 21, 2009 2:05 am
Had new clutch fitted recently and changed cable at same time ,clutch pedal is after only a short while getting a little harder to operate so thinking it may be cable at fault .Fitted Quinton Hazel clutch and cable ,is there a bettter quality cable available ? may fit genuine part from Ford but i suspect their cables are quinton hazel or similar just badged up ford and they aint cheap ."Anyone"
birdy
Postby chris_gilly » Mon Dec 21, 2009 11:27 am
sounds like a cable, my old mk3 used to eat through cables it snapped 3 in about 3 years!
chris_gilly
Postby birdy » Tue Dec 22, 2009 10:54 pm
Ordered new clutch cable at Frauds today with discount £33 and probably made by quinton hazel that can be got for about £12 robbing bas***** Got an oil filter while there £8 .
birdy
Postby dieseldel » Wed Dec 23, 2009 12:09 am
hi
changed more clutch arms than cables, might be prudent to scramble underneath and check that the fork aint bent or broken
it was like that before i touched it !!
dieseldel
Postby Steve B » Wed Dec 23, 2009 1:37 am
I agree, the forks are prone to bending hence reducing the travel
Steve B
Users browsing this forum: Peterr
