Code for Radio Needed Please!
Postby Sara » Tue Dec 15, 2009 7:59 pm
Hi
I wonder if anyone could please give me the code for our radio please? The serial number is
M267930 (at least I think that is the number you require?)
Many thanks, Sara
Sara
Re: Code for Radio Needed Please!
Postby madmark_50484 » Tue Dec 15, 2009 8:03 pm
TRY 2306
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Postby Sara » Tue Dec 15, 2009 8:07 pm
Thankyou madmark, will give it a go
Sara
Sara
Postby Sara » Fri Dec 18, 2009 9:07 pm
Thankyou, how do we actually enter the code? Car Registration appears on the display and when we press a key, we get a 60 second countdown.
Sara
Sara
Postby Terry » Fri Dec 18, 2009 9:20 pm
Hi Sara
Don't know which radio you have but normally you use the row of 6 black station preset buttons low on the face.
Switch on, press button 1 and you should get - - - -, use button one to get the first character up, button 2 for the second e.t.c. then button 5 should enter the code & it will work...........
You can only attempt this a certain number of try's so if you want to wait till madmark comes on, and he can check on the software.
H.T.H.
Terry
Pallet Puller
Terry
Postby WINDSCREENGUY » Fri Dec 18, 2009 10:00 pm
Radio Code Entry
Late Four Digit Ford Radio Codes (no SELECT button)
ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc
Switch the radio on and the word CODE should appear in the display
Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter.
If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist.
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby Sara » Fri Dec 18, 2009 10:49 pm
Thankyou Terry and Grey Van Man. Absolutely brill, can't wait to listen to our radio tomorrow after months without it!!!!
Sara
