1996 Mk 3 van will not start.
Postby shavednut » Sat Dec 19, 2009 5:35 pm
Problem to start van after standing overnight.Will start from a jump,but will flattern a fully charged new battery.Immediatley once started will continue to start on the button all day long.Fitted new starter,battery alternator earths seem ok full service less than 2000mls,any ideas please. Many thanks John.
shavednut
Re: 1996 Mk 3 van will not start.
Postby madbri » Sat Dec 19, 2009 5:37 pm
petrol or diesel?
madbri
Postby shavednut » Sat Dec 19, 2009 6:06 pm
sorry forgot to say its a diesel 190 hi top
shavednut
Postby madmark » Sat Dec 19, 2009 6:34 pm
what oil are you useing? you need 5/30 in this wether :wink:
Postby ake » Sat Dec 19, 2009 7:44 pm
Your 1996 van is a MK5 :wink:
Is the new battery the right size :?:
Does it have an aftermarket alarm or stereo fitted which could be draining the battery :?:
Have you removed and cleaned all the earths :?: Not just looked at them
Postby MrMPuk » Sat Dec 19, 2009 7:45 pm
madmark wrote:what oil are you useing? you need 5/30 in this wether :wink:
5w30 semi-synthetic and it's that all year round.
Postby jay » Sat Dec 19, 2009 8:36 pm
try taking the earth off the battery all night reconnect in the morning and see if it starts ok..if it starts fine then its defintly something draining..if it dont start then its likely the battery at fault...Have you also checked to make sure its charging properly.
mk1 connect tourneo
jay
Postby dumper » Sun Dec 20, 2009 11:26 pm
hi is the cold start advance on the pump working check to see if cable is pulling it al lthe way on
Postby ake » Sun Dec 20, 2009 11:39 pm
When did it last get a timing belt :?:
Postby MinorMatt » Mon Dec 21, 2009 1:48 pm
Its an electrical fault! (or at least thats not helping!)
I would start with Jays suggestion, disconnect the battery earth overnight and see what happens. I would then look to see if its draining current through the alternator
