start stop
start stop
Postby mrmurf » Mon Dec 21, 2009 4:03 pm
hello merry xmas to you all my 1997 none turbo 2.5 di starts first time every time with nuw batt fitted but when starting first thing it starts then stops after a 2/3 secs then starts againe and keeps runing it does this everyday once runing it starts fine all day ? :?
mrmurf
Re: start stop
Postby MrMPuk » Mon Dec 21, 2009 4:09 pm
Are you giving it some revs when you first start it from cold? If not then you need to.
Re: start stop
Postby mrmurf » Mon Dec 21, 2009 4:11 pm
hi yes but not to mutch
mrmurf
Re: start stop
Postby vanfox » Mon Dec 21, 2009 5:04 pm
If you still got the EGR connected check the butterfly ain't closed too much.
Tighten up any slack in the linkage, worked for me.
Some say to start with foot flat to the boards, then release before revs too much......
vanfox
Re: start stop
Postby 62mph » Mon Dec 21, 2009 5:04 pm
Murf - I have a '98 transit van and in this weather it wont tick over first thing in the morning when its cold.. When starting in the morning I just sit there with my foot on the throttle for about 2 minutes at low revs (say quick idle) then its fine. This last week I have been using an block paving brick layed on the throttle pedal while i de-ice the windscreen - Seems to work :D
62mph
Re: start stop
Postby valeterjack » Mon Dec 21, 2009 7:46 pm
Sorry in advance for bragging i give my key a flick van fires into life no need to rev the engine :D :D :D :D
Imagemk5 nothing even comes close
www.scottish-vanners.co.uk
valeterjack
Re: start stop
Postby MinorMatt » Mon Dec 21, 2009 8:03 pm
So does mine... but its apparently better to start with some gas
Re: start stop
Postby mrmurf » Mon Dec 21, 2009 9:12 pm
thanks every one egr linkage loose ill sort it tomorow and see wot happens :)
mrmurf
Re: start stop
Postby alanmercman » Mon Dec 21, 2009 9:14 pm
maybe u got a little bit of air getin into the fuel pipes or filer over nite.u start up on fuel in pump then air enters pump and she dies :wink:
alanmercman
Re: start stop
Postby MrMPuk » Mon Dec 21, 2009 10:23 pm
MinorMatt wrote:So does mine... but its apparently better to start with some gas
Read the owners manual. :wink:
Re: start stop
Postby mrmurf » Mon Dec 21, 2009 10:43 pm
thank you
mrmurf
Re: start stop
Postby kinty » Tue Dec 22, 2009 4:36 pm
and it says"depress the loud pedal" :D
kinty
Re: start stop
Postby mrmurf » Tue Dec 22, 2009 8:09 pm
sorted the loose linkage to the egr cheked for fule leaks none turned the key foot flat to the floor started ran for 3/4 sec cut out tryed again started and she ran fine :?:
mrmurf
Re: start stop
Postby kinty » Tue Dec 22, 2009 9:48 pm
sounds like air ...filter unions ?lift pump unions?
kinty
Re: start stop
Postby trigger » Tue Dec 22, 2009 10:26 pm
62mph wrote:This last week I have been using an block paving brick layed on the throttle pedal while i de-ice the windscreen - Seems to work :D
Like mr bean, you need some rope on the steering wheel now and a broom so you can drive it while sitting on the roof :lol: :lol: :lol:
Mk5 Transit the daddy
trigger
Users browsing this forum: Peterr
