hazard lights
hazard lights
Postby negg » Fri Dec 25, 2009 2:58 pm
hi all ive a 2002 2.0 diesel transit and had some electrical probs with it but all sorted now exept just for one little one with the hazards when i press the hazard button the relay clicks as though its energizing and then nothing happens untill you move the indicator stick to either turn lift or right then the hazards work fine ?? also when i lock the van by pressing key fob the hazards used to flash but dont now ??? could it be the hazard flasher or harard button ??? thanks neil
negg
Re: hazard lights
Postby BigNeil » Fri Dec 25, 2009 3:17 pm
sounds like either a bad earth or a new switch / stalk is required that is how i solved mine as the i think the flasher and the stalk are the same thing
BigNeil
Re: hazard lights
Postby negg » Fri Dec 25, 2009 3:19 pm
the relay is on the steering columm near yr feet and the hazard button is on the dash near the radio
negg
Re: hazard lights
Postby BigNeil » Fri Dec 25, 2009 3:25 pm
bad earth then
i have a mk6 and have driven it for over a year but still think about the mk5 when answering questions - sorry its christmas see and too much champagne already makes reading fuzzy !!
BigNeil
Re: hazard lights
Postby negg » Fri Dec 25, 2009 7:29 pm
i was told it might be the relay or hazard switch ?????
negg
Re: hazard lights
Postby psv-hgv-flt » Fri Dec 25, 2009 8:20 pm
it can be the haz switch but some one might of put wrong relay in. i had to put a relay in from a vauxhall vectra (as i did not have one at the time) and would only work as you discribe and i noticed it had less conectors than the ford ones. SO CHECK THE RELAY NEXT TO STEERING COLUM IF IT IS A FORD ONE..??? :wink:
psv-hgv-flt
Re: hazard lights
Postby negg » Fri Dec 25, 2009 8:48 pm
yes it is and it used to work , i had major electrical probs basically the wiring loom behind the nearside headlight had been rubbing on the body and was shorting things out ! this has nopw been repaired and the hazard prob is the only thing wrong with it ! im sure it cant be a major problem ????
negg
Re: hazard lights
Postby psv-hgv-flt » Fri Dec 25, 2009 8:55 pm
hazard switch then.?? if you flick it on and off kwik try that as i had same prob.?? :wink:
psv-hgv-flt
Re: hazard lights
Postby negg » Fri Dec 25, 2009 9:21 pm
when i do that it just makes the relay click once so it powers it up ???? not untill i turn the indicator stick either way does it make all the hazards flash !! could be switch then ??
negg
Re: hazard lights
Postby ake » Sun Dec 27, 2009 2:04 pm
My money is on hazard switch, all indicators etc are wired thru it
Re: hazard lights
Postby negg » Sun Dec 27, 2009 6:31 pm
ok i will have to try another from scrap yard thanks
negg
