t280 rear axle
t280 rear axle
Postby truckdoctor » Wed Jun 07, 2006 6:55 pm
Hi guys great site , i'm sure this is the place to find the answers to a couple of questions . I'm currently running a T280 and it's come to the end of a very useful life as my works van . Rather than outing it i'm thinking of keeping it for personel transport with a few mods and wonder if the rear axle from a rear wheel drive would bolt straight in or if not does any one know what would be involved . I realise theres no transmission tunnel but the new engine will go in the back with a short prop to the new axle. The other question is what is the most powerful transit in production BHP? . thanks .
truckdoctor
Postby AndyG » Wed Jun 07, 2006 7:00 pm
:shock: Sounds extensive :shock:
Can't see why it wouldn't fit as they do make T280 RWDs :D
135PS TDCI 2.4litre :wink:
Can be chipped :!: :wink: :wink:
Postby AndyG » Wed Jun 07, 2006 7:03 pm
Just had a thought :idea: :( You might not be able to as the floor level is too low :( :(
But it sounds as though you'll be doing a bit of cutting out anyway :lol: :lol: :lol:
Postby truckdoctor » Wed Jun 07, 2006 7:18 pm
Thanks Andyg but what is PS? how much in horse power ?
truckdoctor
Postby AndyG » Wed Jun 07, 2006 7:24 pm
truckdoctor wrote:Thanks Andyg but what is PS? how much in horse power ?
I would gues that translates to about 137 to 140 Bhp
But remember that these diesel engines were designed for torque rather than high revving performance :!: :D
What are you up to :?: :?: :?:
Postby truckdoctor » Wed Jun 07, 2006 7:26 pm
The idea is to use a ford 302 v8 and auto box ,cut out the floor and mount it on a subframe bolted through the chassis IF theres enough length .That should be about 240 bhp , the brakes should good enough as the extra weight (about 250 Kg)in total, is less than the payload
truckdoctor
Postby AndyG » Wed Jun 07, 2006 7:29 pm
Sounds like you'll need a heavier duty rear axle to cope with the extra 100+Bhp :shock: :D :lol: :lol: :lol:
Postby truckdoctor » Wed Jun 07, 2006 7:42 pm
I never new ford made a rear drive axle model of this style van , Is it the semi- high top with the higher floor . I recon it'll stand the extra power if i keep to standard wheel widths
truckdoctor
Postby AndyG » Wed Jun 07, 2006 7:47 pm
Higher floor :!:
Look :!:
Uses the 16" wheels :D
Postby truckdoctor » Wed Jun 07, 2006 7:56 pm
I'll get under the van and check if theres mountings there if so it'll be time to get the parts together , know of a good source for transit parts ? cheers
truckdoctor
Users browsing this forum: DanMK7uk
