Lucas Epic numbers
Lucas Epic numbers
Postby 333jens » Tue Dec 29, 2009 12:21 pm
Hi
I have a 2.5 Turbo transit 1996 (automatic transmission).
The Lucas Epic pump broke down with a damaged axis, so I am looking for another pump,
but I am not sure what numbers to look for on the "new" pump ?
The pump on the car have these numbers : DSA1096 WF8720B010A
Anybody know what the "WF" means, other pumps I have seen are not having any letters in front of the number ?
Can I use other numbers pump as long it is a turbo diesel 2.5 1996 ?
Any help would be good.
Thank you
Jens
Denmark
333jens
Re: Lucas Epic numbers
Postby ake » Wed Dec 30, 2009 10:14 am
You can probably use a pump from another 2.5di Turbo, if its from the same year and engine output
Postby psv-hgv-flt » Wed Dec 30, 2009 11:08 am
he not a uk member, and got a 85ps tourneo. will not be easy.?
psv-hgv-flt
Postby ake » Wed Dec 30, 2009 11:16 am
psv-hgv-flt wrote:he not a uk member, and got a 85ps tourneo. will not be easy.?
I don't know, Tubo Transits are far more common abroad than they are (or were) in the UK
Postby 333jens » Mon Mar 01, 2010 12:21 am
Have not found a pump yet,
but have found out that I should be able to use any "orange" dot epic pump ( I think).
This should be fine for the 85hk TD
Regards
Jens
333jens
Postby MinorMatt » Mon Mar 01, 2010 12:28 pm
an orange dot pump from the first smiley face to part way though '97 should work...
