hazard, hazard
hazard, hazard
Postby petrolhead65 » Sat Jan 02, 2010 4:30 pm
can anyone give me a clue.i have a 96 lwb hi cube but the horn and hazards don't work i checked the fuse it,s ok ,and there is power at the fuse cos when you put the fuse in the alarm squeeks .the indicators work ok till you press the hazard switch then nothing what is it .PLEASE HELLLLP.i start work monday i need them
petrolhead65
Re: hazard, hazard
Postby negg » Sat Jan 02, 2010 4:36 pm
id check the flasher relay just to see if its working ok
negg
Re: hazard, hazard
Postby petrolhead65 » Sat Jan 02, 2010 4:46 pm
negg wrote:id check the flasher relay just to see if its working ok
Thank you i'll check that
petrolhead65
Re: hazard, hazard
Postby Timbo » Sat Jan 02, 2010 5:31 pm
Fuse F14 does hazards and horn..............fifth one from right in bottom row (20 amp).
Timbo
Re: hazard, hazard
Postby Luke » Sat Jan 02, 2010 5:35 pm
if its not the relay might be the switch :?
Re: hazard, hazard
Postby petrolhead65 » Sat Jan 02, 2010 6:11 pm
Timbo wrote:Fuse F14 does hazards and horn..............fifth one from right in bottom row (20 amp).
checked the fuses first thing but relay is ok too
petrolhead65
Re: hazard, hazard
Postby MrMPuk » Sat Jan 02, 2010 7:14 pm
The fact that you've lost both at the same time I'd still say fuse. It may look alright but I'd replace it to be sure.
Re: hazard, hazard
Postby GBBiker » Sat Jan 02, 2010 8:29 pm
If indicators work but hazards don't, that would suggest to me that the hazard light switch is at fault. It's a common failure on the MK5
GBBiker
Wrong Again!
Re: hazard, hazard
Postby petrolhead65 » Mon Jan 04, 2010 5:59 pm
Hi everybody, i found the problem with the hazards .it was the wiring, some clot has cut and joined the wiring at sometime and the joints are the prob.so just got to rewire that and iam on the road
petrolhead65
