Driving on the motorway when on exiting the brake pedal was juddering,it felt like as i pressed it in it was trying to go back up,
i had new pads on about 6000 miles ago,my first thought was a warped disc,any thoughts????????
Phil_G wrote:Id definately say discs.
As much of a bind as it seems, replace both the discs and the pads as well. The pads that are on now will be worn to the old discs and they will accelerate the wear rate of the new discs if retained.
Phil
motorwise wrote:Phil_G wrote:Id definately say discs.
Phil
if you do it youself have some wheel bearings on standby as well - just in case
