locost1 wrote:no. now having trouble understanding all this.
to clarify i need to..
.. check cables and connections to starter and battery, YES
..change battery Charge First
..check the teeth on the starter? Yes
I think iam going to change battery,
the starter is of a 1999 transit, would this be ok or shell i take it back off and count the teeth?
ake wrote:locost1 wrote:no. now having trouble understanding all this.
If both vans are diesel then the starters should be compatible but no harm in checking
Yeslocost1 wrote:hi.i got another battery on charge so will try that.
The starter motor on it is from a Vreg transit. Same teeth as the one i pulled off(13). Would this be ok??
locost1 wrote:just been reading other posts.
There are 2 earth wires on mine. main one goes to a terminal on the starter and the other smaller on goes into the harness.
Should the main neg battery strap go to the starter? Not the mounting bolts but the terminal on the starter!!
Should there be one that connects to engine somewhere??
Anyone live near Warwick, Warwickshire. Midlands!!!!
locost1 wrote:its been on charge now for about 5 hours.
Also there is only one main neg battery lead is this right
