very cold this morning....
Postby firestorm » Mon Jan 04, 2010 10:07 am
so cold my starter motor decided it would go up in a ball of smoke !!!!!!!
question is, what bolts hold it in as i'm at work, i know you got 2 13's for live wire and solind etc. but is it just 2 19's that hold it into the gearbox casing?
and how long does it take to change one could i do it in a hour "going to get keen and do it at lunch" !!!
firestorm
Re: very cold this morning....
Postby MinorMatt » Mon Jan 04, 2010 10:11 am
there are 3 bolts holding the starter to the gearbox, the 1 bolt holding the live on and the solenoid wire...
easily doable in an hour - but the bolt head sizes may not be standard as ford use small heads (13mm)
Postby MrMPuk » Mon Jan 04, 2010 10:57 am
Very hard to tell without van and engine details.
Postby matthew2riches » Mon Jan 04, 2010 11:00 am
Fairly easy to do.
Bolts are whatever are on your van :lol: A good socket set will have all needed tools in.
matthew2riches
Postby firestorm » Mon Jan 04, 2010 11:57 am
it's a mk5 tipper on a S plate, don't worry the trusty mechanic bloke is coming round, was going to do it myself but got limited tools here so wanted to know what size they was so i can see if i got the tools.
firestorm
