Andyg wrote:Halfrauds do a spray![]()
And as the smiley Transits don't have a pollen/cabin filter I would say it's just a matter of spraying through the upper and lower air vents and leave it a while to kill off the bacteriaInstructions should be included
SUREmotorwise wrote:Andyg wrote:Halfrauds do a spray![]()
thats the answer - anti bacterial spray -
Valsheda wrote:So what does an aircon service comprise of, i guess they re-gas it but what else ???
sportscott wrote:My air-cconditioner stinks when you first put it on, is there some that needs cleaning?
Andyg wrote:sportscott wrote:My air-cconditioner stinks when you first put it on, is there some that needs cleaning?
I didn't realise your in the Nertherlands
Do you have a Halfords type shop over there
express post wrote:u can spray a hospital grade diso like glen 20 thought the system.you need to check that no leaves have entry in to the system .remove the fan and clean the fan and before the coil and give it a good spray.
i clean air con for a job is not hard.
sportscott wrote:Yes there are Halfords in Holland, usually in the main shopping centres, which I don't often visit as usually spend my free time with greasy fingers taking something apart. I use a good automotive supplier that is more than happy to fiddle the VAT receipt for me
