whats this then?
whats this then?
Postby bouncymat » Sun Jan 10, 2010 5:37 pm
just been poking about in the back of my van and i have found this above the wheel arch in the back on the drivers side.
the van is a mk6 125t280 lx
i would be particularly interested to find out if it carries power, a signal to indicate if the engine is running/the doors are open.
many thanks
mat
bouncymat
Re: whats this then?
Postby GBBiker » Sun Jan 10, 2010 5:52 pm
Not a clue.
But 7 pins. Possibly for a factory fit towbar?
GBBiker
Wrong Again!
Postby bouncymat » Sun Jan 10, 2010 5:54 pm
van has no towbar.
the connector is on the inside.
bouncymat
Postby GBBiker » Sun Jan 10, 2010 6:24 pm
What I meant was that the loom has the connections should the original buyer have wanted a Ford towbar fitted. I'm sure Ford would have made such a thing plug and play rather than hard wired for the sake of ease in fitting.
A towbar and electrics was an option from the factory so it's conceivable that there should be a plug somewhere for the towbar's electrics.
GBBiker
Wrong Again!
Postby dodgy01 » Sun Jan 10, 2010 6:41 pm
the pins look too small to cary enough current to be tow bar electrics
dodgy01
Postby GBBiker » Sun Jan 10, 2010 6:44 pm
12N electrics don't draw any more current than normal lighting circuits.
It probably isn't anyway. I just guessed based on the 7 pins.
GBBiker
Wrong Again!
Postby angeleye » Sun Jan 10, 2010 6:55 pm
could be socket for vans with rear windows wash/wipe and heated rear window. do you no colours of wires. i think trailer socket would have more pins
angeleye
Postby GBBiker » Sun Jan 10, 2010 8:56 pm
angeleye wrote:i think trailer socket would have more pins
12N electrics are 7 pin :wink:
GBBiker
Wrong Again!
Postby ake » Sun Jan 10, 2010 9:03 pm
Yes but Factory option is for 13 pin :wink:
Postby GBBiker » Sun Jan 10, 2010 9:10 pm
Fair enough, it was just a thought :D
Probably tailgate electrics then?
GBBiker
Wrong Again!
Postby ake » Sun Jan 10, 2010 10:08 pm
Yes or drivers side side loading door :?:
Postby bouncymat » Mon Jan 11, 2010 10:36 am
drivers sld sounds most possible to me - i checked and there is a conection on the other side which is in use (didn't have time to check if they are the same or not)
so would that just be central locking then?
thanks
mat
bouncymat
Postby bazw » Mon Jan 11, 2010 11:20 am
and cargo lights i would think
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby psv-hgv-flt » Mon Jan 11, 2010 11:40 am
bouncymat wrote:just been poking about in the back of my van and i have found this above the wheel arch in the back on the drivers side.
many thanks
mat
lead round to rear aircon and heater.
psv-hgv-flt
Postby angeleye » Mon Jan 11, 2010 12:11 pm
well done that man.i might see if i can utalise mine for something else,
angeleye
