electrical fault ford transit 190 lwb 1998 (r)
Postby timmy1 » Mon Jan 11, 2010 1:57 pm
i went out this morning in my van and stopped outside a freinds house turned off egnition. when i went back started the van and realised the wipers were not working i then noticed that i had no blowers or indicators and no dash lights i have checked all fuses and they are all fine the engine starts the hazards work and the radio and interior light but can not find out what may have caused this anyone got any ideas plz many thanx tim
timmy1
Re: electrical fault ford transit 190 lwb 1998 (r)
Postby angeleye » Mon Jan 11, 2010 2:36 pm
any relays you can check swop about
angeleye
Postby timmy1 » Mon Jan 11, 2010 2:49 pm
havent tried that will do thanks will pr when tried
timmy1
Postby timmy1 » Mon Jan 11, 2010 3:48 pm
hi there tried main fuses not them also just realised no dash clocks working and no brake lights bu headlights work front and rear any solutions welcome plz
timmy1
Postby angeleye » Mon Jan 11, 2010 4:30 pm
did you check any relays you have. my guess is connections or wiring to ignition switch
angeleye
Postby timmy1 » Mon Jan 11, 2010 5:48 pm
hi angel tried the wiring and egnition barrell to no avail going to get some relays tom will let you no the outcome ta
timmy1
Postby Timbo » Mon Jan 11, 2010 6:38 pm
Try relay number 1 (big black one at left side of fusebox) as this is the "ign" relay and feeds a lot of stuff. Give it a wiggle and a tap as you turn on the ignition key and feel if it clicks. You can't swop it for any other relay in the fusebox as it has larger pins than the others.
Timbo
Postby timmy1 » Mon Jan 11, 2010 8:56 pm
big thanx to u angel tapped this relay realy hard and hey presto we have lift off many thanks to you.
timmy1
