cold start
cold start
Postby PHILTHEWHITEVANMAN » Tue Jan 12, 2010 10:19 pm
hi does any one no how to wire up a cold start on a 2.5d 1990 bosh injector pump can i just put it on a switch ty
PHILTHEWHITEVANMAN
Re: cold start
Postby Frag » Tue Jan 12, 2010 11:28 pm
If its the one with the wax heating element that pushes cold start to "off" position,
Its ignition fed thru a temperature switch in the block,wiring it to a fused ignition feed would work tho,as the cold start takes around 4/5 minutes to move to fully off position even if temp switch is by-passed.
Frag
Ford Technician
Re: cold start
Postby PHILTHEWHITEVANMAN » Tue Jan 12, 2010 11:41 pm
i think its the wax one its all part of the pump its black about 2 maybe 3 inches long like a sausage brass nut at one end and a 10mm nut at the other end for power cable i take it the 10 mm nut is for a positive feed . does it need a purmernet power feed or do you send power when you want to stop cold start THANK YOU :D
PHILTHEWHITEVANMAN
Re: cold start
Postby Frag » Wed Jan 13, 2010 1:12 am
Yep,thats the one.
Uses 12V feed to knock the cold start off,connected to 10mm nut at end.
Original wiring uses a 12V (when ignition turned on) feed which goes to a temperature switch in the block that is open circuit till engine start to warm,
switch then makes circuit feeding the wax solenoid & releasing the tension on the cold start mechanism.
My van has this setup & i`ve by-passed temp switch so that solenoid starts to warm as soon as ignition is on as it takes a good few minutes for it to full release,long enough in my opinion for van to run ok.
Click here;
viewtopic.php?f=4&t=39041&hilit=solenoid&start=0
More info on system :wink:
Frag
Ford Technician
Re: cold start
Postby PHILTHEWHITEVANMAN » Wed Jan 13, 2010 7:52 am
thanks frag cold start works
PHILTHEWHITEVANMAN
Re: cold start
Postby finnon » Thu Jan 14, 2010 9:00 pm
what would the cold start on a 1997 non turbo look like?
present van is a 55 reg t280 85ps lwb semi high
finnon
Re: cold start
Postby ake » Sat Jan 16, 2010 11:33 am
The cold start on a 97 is probably the internal one, you cant see it cos its inside the pump
Re: cold start
Postby PHILTHEWHITEVANMAN » Sat Jan 16, 2010 12:32 pm
how long should the cold start stay on for on a 1990 DI . mine is 25 mins do i need a new one Thankyou
PHILTHEWHITEVANMAN
Re: cold start
Postby ake » Sat Jan 16, 2010 1:57 pm
It might be that you need a new thermostat so that your engine warms up quicker, or do what Frag says and by pass the coldstart stat
Re: cold start
Postby Frag » Sat Jan 16, 2010 3:54 pm
PHILTHEWHITEVANMAN wrote:how long should the cold start stay on for on a 1990 DI . mine is 25 mins do i need a new one Thankyou
Depends which pump (lucas/bosch) and which type of coldstart set up,lucas pumps use a waxstat cable type into back of thermostat housing.
Either way 25 mins is way too long !
Frag
Ford Technician
Re: cold start
Postby PHILTHEWHITEVANMAN » Sat Jan 16, 2010 5:33 pm
bosch pump & cold start is on a switch so dont go by engine temperature & its getting 14.2 vollts with engine running butt takes 25 mins to drop off. i could get round it by putting it on 15 mins befor starting the van butt will it be all right leaving power on to cold start all day thankyou
PHILTHEWHITEVANMAN
Re: cold start
Postby PHILTHEWHITEVANMAN » Mon Jan 18, 2010 1:39 am
COLD START fixed off in 5 mins. just need a bit of WD40 sprayed in it . thankyou
PHILTHEWHITEVANMAN
Re: cold start
Postby kennystag » Thu Jan 21, 2010 6:58 am
Hi do all the smileys with bosh pumps have cold starts.
cheers
kenny
kennystag
Re: cold start
Postby Frag » Thu Jan 21, 2010 10:43 pm
No,only earlier ones (pre 97 ish i think :? ) had external coldstarts.
After that its supposed to be internal,in pump.
I prefer early style (they actually work :lol: )
Frag
Ford Technician
cron
