mk5 di alternator wiring
Postby oldskooler » Thu Jan 07, 2010 12:03 am
just a quick question bout the connections. ive just fitted a mk5 di to my mk2 van and im starting the wiring. im using the mk5 battery leads so the main alternator feed is dealt with. the plug on the side of the alternator has two wires which im wondering about as in the mk2 ill just have the one light wire coming from the charge light. could it be that one of these wires comes from the light on the mk5 and the other one runs up the loom and is left to run a rev counter if one is fitted?? or is it more complicated than that?
oldskooler
Re: mk5 di alternator wiring
Postby AndyG » Thu Jan 07, 2010 12:25 am
That's correct, the grey one is for a rev counter pulse and the other one is your charge light :)
Postby oldskooler » Thu Jan 07, 2010 12:36 am
Andyg wrote:That's correct, the grey one is for a rev counter pulse and the other one is your charge light :)
nice one, cheers mate, that saves me going probing my mk5 daily!! :D
oldskooler
Postby AndyG » Thu Jan 07, 2010 12:40 am
From memory, I think the other one is blue :)
Postby oldskooler » Fri Jan 08, 2010 1:30 am
Andyg wrote:From memory, I think the other one is blue :)
spot on bud!! :D same as the mk2. 8)
oldskooler
Postby AndyG » Fri Jan 08, 2010 1:32 am
8)
Postby mat campbell » Tue Jan 12, 2010 2:36 pm
I take it, the "charge light" is the battery sign on the dash board?
Mine has stopped coming on and my battery doesnt seem to charge. Can i assume the alternator has died or is there a fuse in the circuit or something else?
mat campbell
Postby bazw » Tue Jan 12, 2010 2:56 pm
change the bulb in the dash , it feeds back through the dash to energise the alt , no light no power to recharge the battery
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby bortaf » Tue Jan 12, 2010 2:58 pm
mat campbell wrote:I take it, the "charge light" is the battery sign on the dash board?
Take the small wire off the alt and earth it and turn the ign on, if the bulb still doesn't light up try changing the bulb, if the bulb is knackerd the alt wont charge :)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby mat campbell » Wed Jan 13, 2010 2:44 pm
I hope your joking!
mat campbell
Postby GBBiker » Thu Jan 14, 2010 11:33 am
bortaf wrote:Take the small wire off the alt and earth it and turn the ign on
:shock: :shock: :shock:
GBBiker
Wrong Again!
Postby AndyG » Thu Jan 14, 2010 3:21 pm
bortaf is correct :!:
This way, you test the "lamp" circuit is working :!:
What's with the subsequent posts to bortaf's :?: :?
From ign relay, then via fuse no6 (@10amps) energises all the necessary accessories including red charge warning lamp, that will come on when the small blue cable is earthed at the alternator end of the circuit :!:
:idea: prove otherwise :!: :D
Postby bazw » Thu Jan 14, 2010 3:57 pm
its how i test mine for sure lol
bulb in circuit so load on wire means no dead short which im guessing is there fear
2.4 duratorq 115 ps
A.R. 4.27
bazw
